Platform Cable USB II with versatile ARM926EJ-S
does the Platform Cable USB II  or Xilinx Parallel Cable IV (JTAG debuggers)  working with versatile RealView Platform Baseboard for ARM926EJ-S through JTAG ?
Note, different bins assignment
Re: Platform Cable USB II with versatile ARM926EJ-S
Not sure what you really asking in your post.  If you are asking if you can still program Xilinx devices through JTAG with the ARM device in the chain then the answer is yes.  If you asking if ARM debug software can use the cable to debug the ARM processor using the Xilinx cable the answer is no.
Sorry if i not clear in my question, i downloaded processor core into RealView LT-XC4VLX200 logicTile on RealView Platform Baseboard (ARM926EJ-S) and need to debug, the debugger software needs either Xilinx Parallel Cable IV or Platform Cable USB II (JTAG debugger) .So my question was , does the versatile supports this types of cables?
I doubt that there is anyone here that can answer your question.  You should be asking the company that built the board or the company that built your debug software.
Ed
Ok, is there adabter converts 14 to 20 pin ,and wahat about fly wire ?
