Power ML605 board through USB connection?
Is there a way to power the ML605 board through the USB connection like through the PCIe connection?
Thanks!
No, you can't power the ML605 board through a USB connection.
The input power supply for the ML605 is 12V while USB is 5V.
The maximum current for USB is 500mA, the ML605 needs more than that.
