Power consumption SP605
Hello!
 Where I could find information about SP605 power consumption?
Thank you!
Teacher drjohnsmith
Re: Power consumption SP605
is that not in the documentation ?
I found only power on Spartan 6
Teacher drjohnsmith
does the user guide or the associated docs help ?
http://www.xilinx.com/support/documentation/boards_and_kits/ug526.pdf
at the end of the day, I guess it depends on what your doing with the board,
if your running the fpga and associated bits at full speed or is most of it in idle ?
Thanks for your replies!
SRIO contoller is impelement in the fpga, it is occupies near 35% of the die, SRIO is Gbit protocol. But I want to know the whole power consumption of SP605 board.
Teacher drjohnsmith
 the tools should tell you what power is to take max,
     bu tthe peripherals,
         I guess your going to have to meassure the power taken by the board then,
Power consumption is design dependent. In SP605 depends upon which reference design you loaded.
  • Xilinx Power Analyzer (XPA) tool which delivered along with ISE Design pack help to customer accurate power analysis after design implementation.
Mahesh
Observer rho88
In addition to XPA (in ISE GUI, its an option under PAR), Xilinx also provides another power tool called XPower Estimator (XPE), which can be found at www.xilinx.com/power.  With this you don't need an actual design (you can import design data with a mrp file)  and can input some estimated design parameters in order to estimate your max power.  There is a process variation that you can set to max, then just max out your usage and you should have a pretty good estimate for your total max power.  You can apply this to any part really if its supported in the power tools.
Instructor
Instructor
@rho88
Given the choice between:
  • a power estimator which does not use the placed and routed design
  • a power analyser which does use the placed and routed design
I will have greater confidence in the results of the tool which uses the actual design for its calculations.
If you do not have a design for analysis, then there is but one choice between the two:  the estimator.
-- Bob Elkind
SIGNATURE:
Summary:
Observer rho88
I agree completely Bob, the estimator is intended to be used when you don't have a design, which is the impression I got from the OP.  With XPE though its MUCH easier to input data faster if all you want is to try and estimate maximum power for a given device.
Use XPA if you want a full accurate analysis, use XPE if you want a quick estimation w/o a design file or with (yes you loose routing info, like net capacitance, but its quick and easy to use for an estimate).
