Visitor chulhoon
!!! Press ESC to enter System Controller mode
I tried to flash SD card with 2018-12-04-zcu102-desktop-stretch.img and xilinx-zcu102-prod-dpu1.4-2018.3-desktop-buster-2019-04-24.img, but I always see "!! Press ESC to enter System Controller mode." in terminal. How can I solve this problem? I just want to follow the instruction in page 8 of ug1354-xilinx-ai-sdk.pdf.
Visitor chulhoon
Re: !!! Press ESC to enter System Controller mode
I solved myself. The reason was that I was trying to access the wrong serial port. There are four ports when you connect the UART cable to your PC. The manual said we should use the first COM port, but it was wrong in my case. The correct port was the fourth COM port. Eventually, I succeeded to connect the ZCU102 via UART. I hope this would be helpful.
Visitor chulhoon
Visitor anurag_ar
hey!
I'm still getting the same error, for me this error is displayed in the 4th COM port.
I've tried all different things, th ezcu102 doesnt boot even with the pre-built images, what am I doing wrong?
Awaiting your reply!
Thanks!
Hi anurag_ar,
The message you're getting comes from the System Controller Port (usually the 4th COM Port).
Try with Port 1 and see if that helps.
Andres
Visitor anurag_ar
Hi Andres,
Thanks for the reply, but I'm not getting any output from the other COM ports, only thing the displays is the 4th COM port and that has the Press esc error.
Dip switch SW6, is correctly set.
Whatelse could be the problem?
Anurag
