Visitor wazzanan
Problem in Hallo world programm in Zynq in Zedboard
Hi ,
I am trying to print Hallo world using Zynq. but it does not work.
I hav vivado 2017.2 and sdk 2017.2.
sdk give me warning
"executables selected to donwload on the following processors doesnot exist or incorecctly specified. do you wish to ignore them and proceed. 1,ps7_cortexa9_0  "
when I press proceed
nothing happen  I think the Debugger can not find .elf file that means SDK can not generate .elf file what could I do to solve this Problem  :(
thanks for ur help
the same programm works in vivado 2016.1 on another Computer without giving me any warning
Visitor wazzanan
Re: Problem in Hallo world programm in Zynq in Zedboard
@hbucher Thank u for ur replay
I would say I solved the Problem
but I do not know exactly what was the reason for it
I think there is conflict between Path variables
I added ;C:\Xilinx\SDK\2017.2\bin
and I deleted the variables that I think it is not that important
then Restart my PC and it worked
Scholar hbucher
@wazzanan It took me a while to figure why you are running games on a zynq board (Halo).
That said, it looks like the project did not compile. Can you show (screenshot of your Console tab) when you clean and build the project?
Also make sure you are pointing to the version you are compiling (release or debug)
Visitor wazzanan
@hbucher I think u are right but why
make: Interrupt/Exception caught (code = 0xc00000fd, addr = 0x4227d3)
happened :(
Scholar hbucher
@wazzanan So there you have it - the ELF does not exist because the build fails.
You have to find out where the build is failing and why - there is not much information in your post to allow me to help on this particular.
Visitor wazzanan
Hi @wazzanan,
As the issue is resolved, could you mark the response which helped you or your response as solution. This could help other users to find a solution quickly.
Thanks and Regards,
Florent
Florent
