Problem with Tutorials given for Xtreme DSP Video Starter kit Spartan 3A 3400A
I am implementing LAB 6 given on the following xilinx link:
http://www.xilinx.com/products/devkits/DO-S3ADSP-VIDEO-SK-UNI-G.htm
HW/SW Tutorials (ZIP)   file contains LAB 1 to LAB 9 on the above link...........
I succeeded in implementing LAB 1 but while doing LAB 6 : when i execute .elf file i will execute but video is not displayed and hyper terminal shows the following error:
Error writing to FMC Power Control IIC.
Error writing to IIC_device<0x20> during FMC Reset.
Error writing to iic_fmc_mux when trying to access camera #2
Error writing to iic_fmc_mux when trying to access camera #1
Error: Camera not found on Camera 1 connector.
Aborting attempt to configure Camera 1.
Clock generator set to 25.175 MHz.
VFBC Frame Buffer 0 base address 0x10400000
Display Controller Frame Buffer 0 base address 0x10400000
Display Controller Frame Buffer 1 base address 0x1052C000
Display Controller Frame Buffer 2 base address 0x10658000
Display Controller Frame Buffer 1 base address 0x10559000
Display Controller Frame Buffer 2 base address 0x106B2000
Error writing to iic_base_mux when trying to write to iic_dvi_out (CH7301C)
 Error accessing iic_dvi_out (CH7301C)
---- Press Any Key To Continue ----
Error writing to FMC Power Control IIC.                                       Error writing to IIC_device<0x20> during FMC Reset.
Error writing to iic_fmc_mux when trying to access camera #1                                                            Error: Camera not found on Camera 1 connector.                                              Aborting attempt to configure Camera 1.                                       Clock generator set to 25.175 MHz.                                  VFBC Frame Buffer 0 base address 0x10400000                                           Display Controller Frame Buffer 0 base address 0x10400000                                                         Display Controller Frame Buffer 1 base address 0x1052C000                                                         Display Controller Frame Buffer 2 base address 0x10658000                                                         Display Controller Frame Buffer 0 base address 0x10400000                                                         Display Controller Frame Buffer 1 base address 0x10559000                                                         Display Controller Frame Buffer 2 base address 0x106B2000
        Error accessing iic_dvi_out (CH7301C)                                      ---- Press Any Key To Continue ----
Please help me what i should do ????
