Programming Si570 on ZC702
hello, i'm  programming Si570 on ZC702 under the guide of 'xtp181'. But i can't open the 'AR47530' to help me download the SI570 bitstream and ELF files.
What's worse, i'm using vivado 2018.1 now, which means i can't use the zc702_si570.bat to download the bitatream and ELF files. Can you tell me what have be done in the 'zc702_si570.bat' in the 'zc702_si570_programming.zip' file?
the  'zc702_si570.bat' writes like this:
call C:\Xilinx\SDK\2015.4\bin\xmd.bat -tcl download_bit.tcl si570_0.bit
call C:\Xilinx\SDK\2015.4\bin\xmd.bat -tcl download_elf.tcl si570_0.elf
if exist *isWriteableTest*.tmp del /F *isWriteableTest*.tmp
if exist vivado_*.backup.jou del /F vivado_*.backup.jou
if exist vivado_*.backup.log del /F vivado_*.backup.log
if exist vivado_*.str del /F vivado_*.str
pause
Hi @jn_mu :
The zc702_si570.bat file just calls the commands to program the other files in the ready for download folder.
You can also manually call these files in GUI in you current version.
Priyanka
Hello @jn_mu :
You can edit zc702_si570.bat file.
Did you try my suggestion?
Is your issue resolved?
Priyanka
