ragnarok2000
Programming the IDT Clock Chip IDT5V9885 on the ML506 Board
I am looking for the ML50x_Clock_setup.svf (default settings), in my case for the ML506.
But It seems no longer available via the board site (http://www.xilinx.com/products/boards/ml506/ml506_12.1/images.htm)
http://www.xilinx.com/products/boards/ml506/ml506_12.1/files/IDT5V9885_clock_setup.zip
-the link only contains the programming programme Setup_v2.593.exe but not the properties (ML50x_Clock_setup.svf)
Can anyone give me the proper file or link, please?
mcgett
I downloaded the ZIP file in your prior post and the ML50x_Clock_setup.svf is the only file in the ZIP archive. I don't see any mention of Setup_v2.593.exe that you mentioned.
Please don't double post in the future.
