isel_deea
Programming the IDT Clock Chip ML50x Board
Hi! I tried to program the IDT Clock Chip of my ML501 Board, but I don´t find the ML50x_Clock_setup.svf  file. Could you tell me where it is located? Thank you.
barriet
bobelouafay
Is it possible to get all the design not only the .svf file.. I want to modify the output frq of IDT5V9885 using the IDT SW but without sucess ..
I am not sure if the IDT SW is working or not ..
BB
laudolffj
And the answer to the previous post regarding obtaining the entire design for programming the IDT part is....?
ragnarok2000
I am also looking for the ML50x_Clock_setup.svf (default settings), in my case for the ML506.
But It seems no longer available via the board site (http://www.xilinx.com/products/boards/ml506/ml506_12.1/images.htm)
http://www.xilinx.com/products/boards/ml506/ml506_12.1/files/IDT5V9885_clock_setup.zip
the link only contains the programming programme Setup_v2.593.exe but not the properties (ML50x_Clock_setup.svf)
Can anyone give me the correct link?
mcgett
I downloaded the ZIP file in your prior post and the ML50x_Clock_setup.svf is the only file in the ZIP archive.
I don't see any mention of Setup_v2.593.exe that you mentioned.
