Question about Using SI5324,SI570 in ZC706.
Hi. I'm using ZC706 Board.
According to UG953 Table 1-15, SI5324 is connected with AC8,AC7 PIN for MGTREFCLK.
Can I connect the output of SI570 to input pin (REC_CLOCK) of SI5324?
The zc706 board has SI570 and its default output os 156.25 Mhz.
What I want to do is shown below figure.
Q1. Is there a problem with implementation as shown above?
Q2. Does the SI5324 operate normally without any other configuration? Do I need a specific configuration for SI5324?
Thanks!
回复: Question about Using SI5324,SI570 in ZC706.
@kangsungsik Hi,
Ans: I think your solution is OK.
Ans: The Si5324 need to be configured by i2c bus, and you can get the example in the ZC706 bist demo on the Xilinx Website. You can take it as reference and check the Datasheet of Si5324.
@kangsungsik Hi,
