10-25-2011 12:53 PM
hi
i need for some explantion about dvi data[11 : 0]
as i know the VGA has three signal red , green and blue so if there DAC device used "8bit" so if i need to display white color so three signal will be "11111111"
and if i need only green so the red and blue will be "00000000" but the green signal will be "11111111" and so on
but in case DVI controller how can i do that
wait your help
regards
10-25-2011 01:01 PM
In the Chrontel CH7301C datasheet, see Table 4 and Table 5. Combine these with Figure 4 and Figure 5.
-- Bob Elkind
10-25-2011 01:27 PM
dear eteam
i see the data sheet now
but still i did not understand what does P0a,P0b, and P1a,P1b and P2a,P2b
aslo i aske about IDF=0 and how i can determine it ?
regards
10-25-2011 01:47 PM
Figure 4 and Figure 5 illustrate timing of P0a,P0b, and P1a,P1b and P2a,P2b.
Table 4 and Table 5 explains mapping of P0a,P0b, and P1a,P1b and P2a,P2b to R/G/B data bits.
Read the IDF register through the I2C (serial) interface.
Is there someone close by who can help you read and understand the datasheet?
-- Bob Elkind
10-25-2011 02:05 PM
dear eteam
what does P0a,P0b ,... mean ?
also is the read operation of IDF required ?
regards
10-25-2011 02:31 PM
dear eteam00
could you tell me after the configuration is sent to dvi
what is the form for data "example display image" to Data[11:0]?
may be i need to example to understand please
thanks
10-25-2011 02:52 PM
They are labels used in the datasheet to help you understand signal timing and data bit mapping.
No. Your logic writes this register, there's no reason to read it unless you are uncertain of its current value.
-- Bob Elkind
10-25-2011 02:57 PM - edited 10-25-2011 11:20 PM
I don't have time to read the datasheet, understand the datasheet, re-write parts of the datasheet, and explain it to you. Maybe someone else can help you, or perhaps you can click over to the Chrontel website and browse around for tech support options there.
Going forward, it would be helpful to anyone you ask for assistance if you have a clear and concise description of what you are trying to accomplish. For example: resolution, timing, and palette depth (in other words, video format). Such details are important. It would also be helpful to list what you have operating and verified, and what further progress you have made (or tried and failed) to cover the remaining pieces of the overall design.
Until now, all of your questions have been simple ones which are easily answered with a quick search of the datasheet. I'm not prepared to dive into video formats and timing, at this time.
Is there someone close by who can help you read and understand the Chrontel device datasheet?
-- Bob Elkind
10-25-2011 11:30 PM
dear eteam00
good day
after i read DVI controller data sheet i understand that (P0a and P0b) will contain a complete pixel encoded
so for 12 bit rgb {IDF=0} and P0a,P0b,P1a,P1b are used,ok.
now when i need to send data to DVI output is just send 4 time the data D[11:1] but according to specific manner to display any color I need so it is required to arrange the data before I send it to DVI out is this right to no?
Finally I need what is difference between IDF=0 and IDF=1 I know this is in data sheet but I need to more information to understand. and how can set or select or adjust it in controller?
as i understand the DVI controller need for some configuration "in starting - just one time" is there any thing required to do
please i need to solve this problem
regards
11-04-2011 02:14 AM
Hi hodahussein,
I am also looking into how to control the Chrontel CH-7301 chip. In EDK, I found the XPS TFT Controller IP which has built-in logic for configuring the CH-7301 via I2C.
This requires you to use AXI or PLB bus. The TFT controller reads pixel data from an external AXI/PLB memory device. It generates either VGA or DVI signals towards the CH-7301 chip.
I would guess that using this IP simplifies things?
