gma-87
Read Temperature from ZedBoard
hello,
How can i read the current temperature from ZedBoard, i don't need to run an OS like Linux or others, just i search a solution to get temperature values, so i will code PL ( FPGA) to launch alert ( like LED for exemple ), when this value exceed a specific avarage ?
Windows 7 ( 64bits )
Xilinx suite 14.7
vivado and SDK 13.4
ZedBoard
thank you
My blog : www.xilinx-video.blogspot.com
Tags (3)
yenigal
You can use XADC,Have a look at the below pdf.
http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
Satish
yenigal
Satish
smarell
Community Manager
Community Manager
You can use XADC primitive to read the die temperature.
Refer to http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf for details.
Krishna
gma-87
hello,
thank, you for this fast reponse, and i found the solutio i the document http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
gma-87
hello,
thank you same thing, this document present a nice solution
