Reference design files download problem ZCU104
I am attempting to download the RDF0454 zip file that includes the design files for the IPI tutorial of the ZCU104 and for some reason the download is failing. Is there another way to access the zip file?
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0093-zcu104-evaluation-kit-hub.html#
Re: Reference design files download problem ZCU104
Hello @matthewxuereb,
Thank you for your reply.
I will dowload the design and share the design over the EZ-Move folder.
Naveen
The link(https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0093-zcu104-evaluation-kit-hub.html#) is working at my end. Can you please let me know what error message you are getting? Please share the screen shot of rhe error message.
Naveen
The link is working for me as well, however I'm having problems when downloading the rdf0454 file. The file always fails to download. I have tried downloading it with different devices and internet connections.
Naveen
Hi can you please provide a link to the EZ-Move folder?
Thanks!
I would again asked the same question which @nmanitri  asked you before, what is the error message observed in Vivado Hardware manager?
1. are you able to establish the JTAG chain?
2. what is the version of VIVADO?
3. what is the version of rdf0454 you are downloading?
4. Do you see all LEDs on the board lit perfectly when board is powered?
5. Did you check mode pins on board if they are JTAG ready?
Kunal
