Regarding SP605 COMPACT FLASH
I am trying to transfer imager from spartan6 sp605 to pc using ethernet. In the base reference design interface it is showing "link is connected to fpga" but ethernet status LEDs are not active. I want to add an image from compact flash and i want to transmit it using ethernet.
In the getting starterd manual  it is mentioned that to load from the CF card, reset the FPGA by pressing the system ACE CF resetr button (SW9)".
But how can i select the image fromthe compact flash?
Hemanth
The following AR http://www.xilinx.com/support/answers/40399.htm verify switch settings and also heps to debug Board problems( if exists)
HI,
Gone through the above link & everything was fine. I want to access the image file from Compact flash card. How is it possible?
Hemanth
