Observer torokb
SDK flash program with shared memory bus multiplexer
Hi!
I use a Digilent Nexys3 board, and now I'm trying to download a bit file (with config data and bootloader program), and an srecimage into the parallel flash. The configuration and the bootloader are OK (SDK srec_bootloader template). But SDK->Xilinxtools->ProgramFlash seems not working. I think the ProgramFlash option somehow not compatible with the digilent shared memory bus multiplexer ("No usable flash memory controllers were found in the hardware system."). Should I connect the flash with another memory controller core? Any tips were to start workaround this problem?
I think it must be simple, many people use this board with applications need external RAM, program memory, and bootloading.
thanks,
Bence
Re: SDK flash program with shared memory bus multiplexer
i looked at the MHS of your design and it looks that there is no axi_emc controller.
Refer to http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/platform_studio/ps_r_dld_program_flash_memory_dialog_box.htm
So to run flashwriter on this board, you have to configure axi_emc controller to connect to the BPI flash.
--HS
Does the nexys3 board have a SPI flash or a BPI flash? Flashwriter in SDK is used to program BPI flash.
--HS
Observer torokb
It has a PBI flash, wich shares data bus with the SRAM. The board uses a digilent memory controller to handle this shared bus.
The board has an PSI flash too. Maybe I will try to use that.
If the board uses BPI Flash, then you should be able to program the Flash using Flashwriter.
Share the MHS so i can comment about it.
--HS
Observer torokb
MHS in attachments.
The BPI is the "FLASH" int "d_shared_mem_bus". (The other two device are the RAM, and an SPI flash.)
--HS
Observer torokb
So I have to find another way to program the BPI. Maybe digilent Adept.
Thank you.
Visitor dcorreia
Did you figure out how to do this, I need to figure to do the same thing
