SMC USB3220 on zc706
I'm trying to configure the USB3220 on zc706 with petalinux 2016.2, I tried to configure zc706 as Device mode on petalinux side, also set the jumper as following:
J11    OFF
J10    OFF
J48    1-2
J50    1-2
J49    1-2
J51    2-3/1-2 tried both
But after I powered on the board, there is no any new device on PC, also seems there is no power at all on the USB, it suppose the windows 7 Device Manage detect the device and send request message to the board? But it seemed not happened.
Any suggestion will be appreciated.
Re: SMC USB3220 on zc706
hi,
you can refer the BIST USB example design as given in this link
http://www.xilinx.com/support/documentation/boards_and_kits/zc706/14_5/zc706-bist-pdf-xtp242-14.5-c.pdf
--hs
