Participant manish.ranade
SP605 and DDC lines on DVI connector
The issue of FET between DVI connector (on DDC lines SCL, SDA) and FPGA pins  was being discussed in some other thread.
Creating a fresh thread to have categorical answers.
In summary, the discussion in progress is:
Q: On SP605  IIC lines related to DVI connector has some FET based circuit. Is it voltage translators?
A: The FETs would shut off as the signal level on the FPGA pin side approached the gate voltage (2.5V).  So yeah, the FET serves as a voltage translator.
Q:The signals here (SCL, SDA)  are bidirectional in theory. Those are from DDC channel lines of DVI connector. This translation scheme works well for bi-directional line?
Re: SP605 and DDC lines on DVI connector
Thanks Bob.
To end this thread here, giving a  link  where Bob has explained the circuit in great detail:
http://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/SP605-and-FMC-XMC105-interface/td-p/123928
Instructor
Instructor
I'll answer in the original thread.
- Bob
SIGNATURE:
Summary:
Thanks Bob.
