485337
SPI external programming header KC705
Hi.
KC705 has J7 - SPI external programming header. What can I connect to this header? Thanks.
austin
To program the on-board QSPI device.
Austin Lesea
Principal Engineer
Xilinx San Jose
485337
What devices can I connect to this header? Only Platform Cable USB II?
austin
Used for factory programming,
You may program it through Vivado hardware_manager from the Kintex device, through JTAG (not using J7).
Austin Lesea
Principal Engineer
Xilinx San Jose
