Visitor pt_zheng
Serial port and SD card problem with ZCU102 evaulation boards
We built a system with bram and implement it on ZCU102 evaluation boards. Then we tried to use the serial port of SDK to read the data in bram and write the data to SD card. We have two ZCU102 evaluation boards and one successed, but another one didn't show any message on the terminal. The successful one was bought about 2 years ago and the failed one was just bought. We use Vivado 2016.4.
What details I need to know to use the ZCU102 evaluation boards to write data to SD card and use the serial port?
Re: Serial port and SD card problem with ZCU102 evaulation boards
Figure2-14 in UG1209, you described is how to set up JTAG Boot.
There is a difference in SW6 setting for SD boot between ZCU102es and ZCU102production.
In ZCU102 production,
Thank you
Yoichi
This forum is based on the cooperation of everyone who participates.
Kindly note - Please mark the Answer as "Accept as solution" if information provided is helpful.
Hello @pt_zheng
You may use ZCU102 ES(Engineering Sample) and Production version.
I think old one is ES because Vivado2016.4 has ES1's board setting as bellow.
If you use another ZCU102(production), you need to rebuild with ZCU102 production board setting.
It is in newer version of Vivado.
Thank you
Yoichi
Hi @pt_zheng
Are the BIST and BIT test for the new board present at xilinx.com? If not, can you please try and share the results with us.
https://www.xilinx.com/products/boards-and-kits/ek-u1-zcu102-g.html#documentation
Rohit
Visitor pt_zheng
Thanks for your help @katsuki
I upgraded the verson of vivado to 2018.3. Then I followed the step in ug1209 to build a hello world project, but the serial termininal in SDK still showed nothing.微信图片编辑_20200113001221.jpg
Thank you
Yoichi
Hello @pt_zheng
If you still do not see HelloWorld.
You can open 4 screens in a TeraTerm on your PC, because the ZCU102 has four COM ports in one USB cable.
I think it will be displayed in one of the four.
Yoichi
Visitor pt_zheng
Hello @katsuki
I have solved the problem. The reson is that the default DDR configuration does not match the hardware of the newly purchased board. I changed the configuration according to the data sheet and solved the problem.
Thanks for your help.
Zheng
Hello @pt_zheng
Oh, that's right.
AR#71961 - Zynq UltraScale+ MPSoC ZCU102 and ZCU106 Evaluation Kits - DDR4 SODIMM change.
Thanks!
