Setup Zynq US+ zcu104 for the first time.
Hi Everyone,
I am really confuse. How to setup Zynq US+ zcu104 for the first time. There are so many sources are available, but I don't find anyone of them complete.
Could you please tell me which one I should follow strictly and where can I find the latest boot image?
It would be better if there were some video tutorial for setting up this FPGA board.
With Regards,
Saini
Re: Setup Zynq US+ zcu104 for the first time.
Hello @saini ,
From what i know all of the drivers would be installed automatically for you.
If any further info is needed, you should be able to find this here: https://github.com/Xilinx/reVISION-Getting-Started-Guide
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @saini ,
Please use the board's quick start guide (https://www.xilinx.com/support/documentation/boards_and_kits/zcu104/xtp482-zcu104-quickstart.pdf) to set up and configure the board, run the built-in self-test (BIST), install the Xilinx tools, and redeem the license voucher. The guide also provides a link to additional design resources including reference designs, schematics and user guides.
Hope this helps.
Kind Regards,
Anatoli Curran,
Hi @anatoli ,
Thanks for your reply. Do I also need to install HDMI and other drivers or is it already installed? If yes, Could you please provide the tutorial or documentation and link to the drivers?
With Regards,
Saini
Hello @saini ,
Hope this helps.
Kind Regards,
Anatoli Curran,
