Visitor arenas
Spartan 3A DSP 1800.Error programming the SPI flash memory
Dear all,
I am trying to program the SPI flash memory using the JTAG  interface and the IMPACT program, without success. I created the PROM files and I tried to charge them with the IMPACT program as a SPI PROM M25P64.
I am obtaining the following error:
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file C:/Xilinx/11.1/ISE/spartan3adsp/data/xc3sd1800a_spi.cor.
'1': Downloading core...
done.
'1': Reading status register contents...
CRC error : 0
IDCODE not validated while writing FDRI : 0
DCM matched : 1
status of GTS_CFG_B : 1
status of GWE : 1
status of GHIGH : 1
value of VSEL pin 0 : 1
value of VSEL pin 1 : 1
value of VSEL pin 2 : 1
value of MODE pin M0 : 1
value of MODE pin M1 : 1
value of MODE pin M2 : 1
value of CFG_RDY (INIT_B) : 1
DONEIN input from Done Pin : 1
POST_CRC_ERR error : 0
SYNC word not found : 0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 1111 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
INFO:iMPACT - '1': Checking done pin....done.
'1': Core downloaded successfully.
'1': IDCODE is '898913' (in hex).
'1': ID Check failed.
INFO:iMPACT:2488 - The operation did not complete successfully.
INFO:iMPACT - SPI Device not found.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time = 3 sec.
I tried to solve it searching on Internet but I don't succeed.
I appreciate any help!
Thanks in advance.
Re: Spartan 3A DSP 1800.Error programming the SPI flash memory
Did you try with the latest version of the tool?
Thanks,Vijay
