Spartan 3e Starter Kit amp LTC6912-1 y adc LTC1407A-1
Im trying to get analog data from amp and ADC with microblaze and SPI core.
I need some help with de C code to get 2 channels data.
Instructor
Instructor
Re: Spartan 3e Starter Kit amp LTC6912-1 y adc LTC1407A-1
Your code looks pretty good, so far.
Have you taken a look at the reference design code for this board?
-- Bob Elkind
SIGNATURE:
Summary:
I have read the entire manual of your Spartan 3e Starter Kit, especially the part ofADC.
I successfully assigned pins for communication with the LTC6912-1 AMP and theADC LTC1407A-1 in the UCF file.
You've added a IPCORE general purpose I / O. To manage ADC_COV pin, because it has a peculiarity.
I have developed a code for handling input and output SPI.
1. Configure the SPI IPCORE as a teacher. You select the phase 1. And enable bitSPE. Disable the LOOPBACK MODE bit. Established at 1 bits reset the RX and TXFIFOs.
2. Wrote the SPIDTR registry values​​, but when hardware debug mode are no values ​​in the memory register.
What could be the problem?
I am working with SPI v 2.01a on SDK11.1.
could you show me the project with microblaze, i  couldn't work it out .thank you !
have you succeed with micorblaze? after reading you posts, I still felt confrusated.
