10-18-2017 04:22 AM
Hello
I am trying to follow the steps for
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.2+-+Design+Module+6
When I open the project in Vivado to build the PL portion, the following constraints files are missing:
timing.xdc
pin_zcu102.xdc
misc.xdc
I am using the following version:
rdf0429-zcu102-es2-base-trd-2017-2.zip
Does anyone know where I will be able to find these files? I searched through the extracted ZIP file.
10-25-2017 12:39 AM
Hello @gteague
Yes, In previous versions of ZIP files it was missing xdc files.
Please download latest versions of TRD from below link:
https://www.xilinx.com/products/boards-and-kits/ek-u1-zcu102-g.html#documentation
Please go for rev 2 files.
Make sure you are using the Vivado version that is bundled with 2017.2 SDx, not stock 2017.2 Vivado as that will not work.
Hope this helps.
Thank you.
10-24-2017 02:55 PM
Hi @gteague,
The files are located under:
rdf0429-zcu102-es2-base-trd-2017-2-rev2.zip\rdf0429-zcu102-es2-base-trd-2017-2\pl\zcu102_es2_base_trd\zcu102_es2_base_trd.srcs\constrs_1\imports\constrs
I downloaded the zip file from the documents page for the ZCU102.
Sam
10-25-2017 12:39 AM
Hello @gteague
Hope this helps.
Thank you.
