The idcode read from the device does not match the idcode in the bsdl File.
I have recently acquired the ML605 evaluation kit, but when I try to configure the FPGA using iMPACT I always get the same message:
Device IDCODE :    00000000000000000000000000000000
Expected IDCODE :   00000100001001010000000010010011
Prior to configuring I did initialize the JTAG chain, I get the message "Identify Succeeded" in iMPACT, and the chain chain scheme appears with the TDI going first into xccace and then into the FPGA xc6vlx240t and then into the TDO
Even without configuration file assignments, upon initializing the JTAG chain, when I right-click on the FPGA in the chain and click on "Get Device ID" I get a red "ReadIdcode Failed" pop-up message.
I also tried using the Debug menu option IDCODE Looping, but still get the same message: The idcode read from the device does not match the idcode in the bsdl File.
Finally, I configured the FPGA successfully with the pre-installed demonstration design that came on the compact flash card that came with the evaluation board package, the Built-In System Test (BIST) design, and ran all the tests that are part of this design, and according to this the board's functionality is good. Yet, I cannot configure the FPGA using the JTAG boundary scan configuration. Please advise on what I can do to fix this,
Thank you in advance,
Dusan
Scholar austin
Re: The idcode read from the device does not match the idcode in the bsdl File.
It is marked as a production device.
An ES device would be marked with an ES (first silicon), ES1 (a mask revision, still not production), or in some rare cases, ES2.
So, it is a bad device if it will not report its IDCODE.
Contact your distributor to discuss.
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
d_v,
"recently acquired" as in purchased from an authorized Xilinx distributor?  If so, you should contact them to discuss.
A production device that is obtained through the authorized channels should not have this issue.
An ES device will have potential errata documented by ES number (ES1, ES2, etc.).
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi Austin, thank you for your reply. Yes, I have purchased the device through Avnet who is the distributor for Xilinx here in the area (Ottawa, ON, Canada). I will be contacting them.
Concerning the ES numbers you mention, where can I find these.
Thanks again,
Dusan
Scholar austin
d,
If you can read the top of the device (not blocked by a heatsink), the part number line will have "ES" or similar markings.
Austin Lesea
Principal Engineer
Xilinx San Jose
Hello  dusan_vobornik,
To check the silicon version of the device on your board please follow procedure given in following link :
https://www.xilinx.com/support/answers/37579.html
Thank you.
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. It helps other users to find the correct answers.
1) In case of using your own design, please check whether the part number in your project and the part number of the device (Part marking) is exactly same or not?
2) Reload ML605 factory supplied designs and try once
3) If still problem exist please then verify as per https://www.xilinx.com/support/answers/40398.html  steps and  find out are there any board problem exists
Hi Austin,
I've removed the fan and the heat-sink and check the numbers on the FPGA, but there is no ES printed on it. These are the numbers printed on the FPGA I have:
XC6VLX240T
FFG1156ACW1609
DD5203344A
1C
Hi Umamahe,
Concerning your first suggestion, when I click on my design properties I did check that the device and package number matches the device and package numbers printed on my FPGA. Is there any other place in the design where the device part number is specified that I should be checking?
Concerning the second suggestion I did reconfigure the FPGA using the Xilinx supplied design that came on the compact flash card, the built in system test design, and it works fine - all the tests specified there are successful, yet I still can't get the FPGA's ID code after initializing the JTAG chain. Is there another .bit file from Xilinx that I could try to configure the FPGA using the boundary scan JTAG configuration?
Scholar austin
Austin Lesea
Principal Engineer
Xilinx San Jose
