Visitor jasperlan
The isp pipeline problem of reVISION filter2d example
When i use the ZCU104 to test the reVISION GET START EXAMPLE filter2d.
The output video is too green .So i want to modifly the pipeline isp by follow step
root@xilinx:~# yavta --no-query -l /dev/v4l-subdev4
Device /dev/v4l-subdev4 opened.
--- User Controls (class 0x00980001) ---
control 0x0098c9a1 `CSC Brightness' min 0 max 100 step 1 default 50 current 50.
control 0x0098c9a2 `CSC Contrast' min 0 max 100 step 1 default 50 current 50.
control 0x0098c9a3 `CSC Red Gain' min 0 max 100 step 1 default 50 current 50.
control 0x0098c9a4 `CSC Green Gain' min 0 max 100 step 1 default 50 current 50.
control 0x0098c9a5 `CSC Blue Gain' min 0 max 100 step 1 default 50 current 50.
5 controls found.
root@xilinx:~# yavta --no-query -w '0x0098c9a4 0' /dev/v4l-subdev4
Control 0x0098c9a4 set to 0, is 0
control 0x0098c9a4 `CSC Green Gain' min 0 max 100 step 1 default 50 current 0.
5 controls found.
But it doesn't work  . I also change the brightness parameter, it doesn't work ,too.The output of the video is still very green.
Do i use the incorrect way to modify the parameter ? Is there any other way to change the preset of pipeline .
Jasper
