Use of SP601 evaluation board (spartan 6 FPGA)
Hello everyone,
I 'm using a SP601 evaluation kit but I cannot start working with it.
After following with precision the entire quickstart manual, I ran a communication terminal for testing the board with the BIST, only the LEDs and UART work. No other test respond.
Also, the Base Reference Design Interface (v 2.0.6.0) keep saying : "Not connected to FPGA".
Some of the ethernet LEDs shine.
Any idea ?
Thank you
Bastien
Hi @bsejourne,
When you run BIST test for FLASH test and other, what do you see on tera term? do you see test failed message on the tera term?
-Pratham
Hi Pratham, and thank you.
Here is what I get :
- Timer test : Random characters. Then every time I press "CPU Reset" button I get some more, but still random.
- Flash test : "Initialized Flash library successfully" (sometimes the letters are combinated in wrong order), then "Unkerror test failed. Press PROG to continue."
- IIC test :
"SRECORDS at: 0x871a0000
Bootloader: Processed (0x)00000320 S-records
Executing program starting at address: 00000000
                         IIC EEPROMet:
Writgdattoeoma008 00003040607000C00F
                                    Readingdata frCparig adaa
ing at address: 00000000"
- Ethernet loopback test
XPS Ethernetlite Loopback Example:  Failed
- Switch test
Data read from GPIO Input
is 0xD
Press the 'PROG' buttn to continue.
- External memory Test
Multi-Port Memory Controller Memory Test
Testing address range 0x50200000-0x57FFFFFF.
Iteration 1 of 1
Pass A) ICache:  On, DCache:  On
        TEST0: Write all memory to 0x00000000 and check
                Writing...
                Reading...
        Test Complete Status = SUCCESS
        TEST1: Write all memory to 0xFFFFFFFF and check
                Writing...
                Reading...
        TEST2: Testing for stuck together bank/row/col bits
                Clearing memory to zeros...
                Writing and Reading...
        TEST3: Testing for maximum ba/row/col noise
                This test performs 16 word writes followed by 16 word reads
                Each 64 bytes inverts the ba/row/col address
                Initializing Memory to 0xA5A5A5A5...
                TEST3.3 - ERROR #1: Address = 0x57DB5380, Data Expected was 0xFF
