Using si5324 in zc706.
Hi. i have question about si5324. Now i', using zc706.
In UG954( zc706 user guide),  si5324 out clk is used for MGTREFCLK1 in Quad 110.
• Quad 110:
° MGTREFCLK0 - FMC_HPC_GBTCLK1_M2C clock
° MGTREFCLK1 - SI5324_OUT_C_P/N jitter attenuator clock
° Contains 4 GTX transceivers allocated to FMC_HPC_DP[7:4]_C2M_P/N
SI5324 is jitter attenuator, so there are input clk pin/ output clk pin like below.
REC_CLOCK_C P/N are input clk pins for si5324.
And REC_CLOCK P/N are connected into AD20,AE20 pin on FPGA XC7Z045.
My questions are
1. If i want to use 200Mhz for GT_REF_CLK,  i have to make 200Mhz by using clocking wizard, and then output this clock to AD20,AE20.
   Am I right?
Re: Using si5324 in zc706.
