kmshaw_saic
VC707 Board Users...Help!
I have a VC707 board and i've been having problems getting my application to run in DDR3 memory. So, to test the DDR3 memory, I ran the DDR3 test in the BIST design residing in flash on the board. It passed the test multiple times.
I then tried the BIT file in the "ready_for_download" folder in "rdf0195-vc707-bist-c-2014-1.zip". It will either always pass the test or crash and become unresponsive at TEST0 of PASS A. If it fails, it requires a cycling of power to get things working again. Simply downloading the BIT file again will not get it to work.
I then tried the BIT file in the "ready_for_download" folder in "rdf0195-vc707-bist-c-2014-2.zip". This time, it does not crash, but fails periodically. Here is a typical failure:
**     VC707 - axi_7series_ddrx TEST                  **
V7 axi_7series_ddrx Memory Test
Testing address range 0x80080000-0x80082000.
Iteration 1 of 1
Pass A) ICache:  On, DCache:  On
        TEST0: Write all memory to 0x00000000 and check
                Writing...
                Reading...
        Test Complete Status = SUCCESS
        TEST1: Write all memory to 0xFFFFFFFF and check
                Writing...
                Reading...
        TEST2: Testing for stuck together bank/row/col bits
                Clearing memory to zeros...
                Writing and Reading...
        TEST3: Testing for maximum ba/row/col noise
                This test performs 16 word writes followed by 16 word reads
                Each 64 bytes inverts the ba/row/col address
                Initializing Memory to 0xA5A5A5A5...
        TEST4: Testing for Inverse Data at Address
                Writing...
                Reading...
                Number of errors in this pass = 0
Pass B) ICache: Off, DCache: Off
                Writing...
                Reading...
                Writing...
                Reading...
                TEST3.3 - ERROR #1: Address = 0x80081FC4, Data Expected was 0xFFFFFFFF, Data Received was 0xFFFF11FF
        Test Complete Status = FAILURE
                Writing...
                Reading...
                Number of errors in this pass = 2
axi_7series_ddrx test iteration #1 has FAILED!
Total number of errors for all iterations = 2
### Program finished with errors ###
Press any key to return to main menu
Sometimes the DDR3 test will pass with no errors. When it fails it is always that same byte of data.
So, I have three versions of the BIST DDR3 test using Xilinx -supplied BIT files that produce three different results. One always works. I think I have a bad VC707 or something is marginal and causing two of the three BIST BIT files to fail the test.
Can someone out there with a VC707 run the BIST BIT file in the "ready_for_download" folder in "rdf0195-vc707-bist-c-2014-2.zip" archive and see if it passes the DDR3 test? I'm getting failures of the DDR3 test on maybe 7-8 runs out of 10 runs of the test. If it works for you then I'll submit an RMA to Xilinx.
Kevin
Tags (3)
kmshaw_saic
Update...the VC707 had an intermittant DDR3 issue. I RMA'd the board. The new board works fine.
Kevin
kmshaw_saic
Kevin
