VC709 TRD for Vivado 2013.3
Please update TRD for VC709. Current version available at xilinx.com is for Vivado 2013.2 and it is not compatible with Vivado 2013.3
I installed Vivado 2013.2 side-by-side and tried to run synthesis of TRD with Vivado 2013.2. However it fails:
 "[Designutils 20-1365] Unable to generate target(s) for the following file is locked: c:/Anton/v7_xt_conn_trd/vivado/project_1/xt_connectivity_trd.srcs/sources_1/ip/ten_gig_eth_mac_axi_st_ip/ten_gig_eth_mac_axi_st_ip.xci
Locked reason: IP 'ten_gig_eth_mac_axi_st_ip' requires a license but no valid license was found. No useable outputs are available for this IP. However license checkpoints may prevent use of this IP in some tool flows. Please select 'Report IP Status' from the 'Tools' menu for instructions to unlock.".
and
"[Designutils 20-1365] Unable to generate target(s) for the following file is locked: c:/Anton/v7_xt_conn_trd/vivado/project_1/xt_connectivity_trd.srcs/sources_1/ip/ten_gig_eth_pcs_pma_ip/ten_gig_eth_pcs_pma_ip.xci
Locked reason: IP 'ten_gig_eth_pcs_pma_ip' requires a license but no valid license was found. No useable outputs are available for this IP. However license checkpoints may prevent use of this IP in some tool flows. Please select 'Report IP Status' from the 'Tools' menu for instructions to unlock.
Firstly VC709 TRD is not yet available on Xilinx.com. The problem is to do with the licensing of the IP's in your TRD. You should not use the 2013.2 TRD in 2013.3.
For the failure in 2013.2 to synthesize the IP you definitely need to have a license for the following.
1) ten_gig_ethernet_mac
2) ten_gig_ethernet_pcs/pma.
These are IP's which have to be purchased and hence you definitely need the license to run them.
You can order the evaluation license for both of them from the IP product pages.
1) http://www.xilinx.com/products/intellectual-property/DO-DI-10GEMAC.htm
2) http://www.xilinx.com/products/intellectual-property/10GBASE-R.htm
Generate the evaluation licenses from these home pages and use them in your design to re-synthesize the TRD's. WIthout these licenses you cannot run even in the Vivado 2013.2 or Vivado 2013.3.
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
Anirudh
Thank you very much for fast reply! I solved the problem with licences by generating them in at Xilinx's website
Support->Downloads and Licensing->Get license.
However the main issue is the absence of TRD for 2013.3. We use 2013.3 because there are many other bugs has been fixed in 2013.3.
Unfortunately the TRD for 2013.3 is not yet available on Xilinx.com.  Meanwhile please work with 2013.2 and let us know if you are facing any problems so that we can help you out.
Anirudh
Please Mark as Answer in case you found this useful so that it can help other on Xilinx Forums.
Anirudh
