Newbie mbanna
VC7203 HP/HR IO Banks
I have two questions about "VC7203 Characterization Kit" including "XC7VX485T-3 FFG1761E FPGA"
1. I see that the kit has: 200 MHz 2.5V LVDS Oscillator, that is connected to E18/E19 FPGA pins.
It is clear that E18/E19 is LVDS 2.5 "VCCO required is 2.5" but in the schematic they are part of BANK 38 which is supposed to be HP bank with VCCO = 1.8
According to ug471, all IOs per bank should have the same VCCO voltage, then can you clarify how E18, E19 are connected to HP bank?
2. FMC VADJ is connected to VCCO_HP. Does this mean that all FMC connector pins can be configured to LVCMOS18 or LVDS 18 ?
Re: VC7203 HP/HR IO Banks
200MHz is used for MIG reference clock but 2.5V is permitted with coupling network
For Q1 please refer this link http://www.xilinx.com/support/answers/40603.html
Q2.
http://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/FMC-VADJ-HP-HR-and-7-series/td-p/202747
Hope this helps
Vanitha
LVDS is always LVDS regardless of the voltage supply for a driver and it is always 1.25V +/- ~200mV.
