VCU
可以提供使用VCU的example design吗?
请转到下面的链接,您将找到的几种示例设计。
如果您能准确地告诉我您要寻找哪种示例设计以及针对哪个板,我可以为您提供更多帮助?
link : VCU118
        VCU110
        VCU128
        VCU129
Please give Kudo and Accept as a Solution if solution provided seems helpful.
What we use is zcu106
Hi @MQi ,
I thought you are asking about Virtex Ultrascale board when you mentioned "VCU".
But I guess from VCU, you mean Video Codec Unit.
You can find VCU example design for ZCU106 on the below link :
doc : https://www.xilinx.com/support/documentation/boards_and_kits/zcu106/2020_1/ug1250-zcu106-vcu-trd.pdf
https://www.xilinx.com/search/site-keyword-search.html#q=ZCU106%20VCU&firstQueryCause=searchFromLink&firstQueryMeta={%22JSUIVersion%22:%222.4382.16%3B2.4382.16%22}
Kuldeep
