VCU108: Programming Si570 on XM104
I'm trying to program the Si570 programmable clock on a XM104 FMC card via the VCU108 System Controller.
Unfortunately the board responds with an error:
FMC HPC0 card present
XM104 not found on FMC HPC0 Interface
I tried with both FMC connectors, same issue.
Programming the clock of a XM107 in a similar way works without problems.Anyone got a clue what could be the source of this problem?
Re: VCU108: Programming Si570 on XM104
@progwolff An erased EEPROM is not a good sign. The EEPROM contains identification details of the card as per FMC specification. I believe that is the reason you seeing the issue
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
Update: I noticed that the EEPROM of the XM104 is cleared (all entries 0xFF).
Might this be the problem? How does the system controller check for a specific FMC card?
- Giri
Before returning my XM104 I would like to try writing the correct data to the EEPROM myself.
Could anyone give me the correct data that usually is written to the EEPROM of a XM104?
