Visitor magedsallam
VCU118 IBERT QSFP with active cables ( No link)
Hi all,
                   I have VCU118 in hand  and I have done the IBERT test based on XTP440 and everything works fine , but then I  tried  to connect the two QSFPs to each other by an active cable   using Mellanox MFA1A00 100G cable  , I did modify the design to be with 25gb/s per lane , which is working with the loopback but not working with the active cable  ,  Anyone knows what is needed to make it work with the active cable?
Visitor magedsallam
Re: VCU118 IBERT QSFP with active cables ( No link)
Problem solved _ just had to program  QSFP Reset , low power and  mode sel pins
@magedsallamWhat output is being shown in the picture? What are links 24 and 25?
Visitor magedsallam
These are the links of 2  QSFP lanes from Quad 231 and Quad 232   there are 6 more lanes with the same result
Hi @magedsallam
To isolate what the issue is, can you try PCS/PMA loopback ? what is the status of the Q/CPLL Lock ? Probably an extended snapshot showing all the parameters of the H/W manager Serial IO GUI would help.
Hope you have the free running system clock too?
Visitor magedsallam
@magedsallam May you please share how did you do that? what reference did you use?
