Visitor cheebi7
VCU118 - SGMII AxiEthernet - Axi Initialization
Dear Community,
I know there are several other questions regarding this topic. But none of them worked for me nor did they presumably have the same issue.
I am trying to use Axi-Ethernet-IP-Code on a Virtex UltraScale+ on the VCU118 Eval Board.
Before posting IP-configuration and startup code, I want to state my observations and questions:
* The Phy does complete autonegotiation with 1000MBps as requested.
* However, the TEMAC-status register (PPST 0x30) doesn't show rudi_c (bit2), link sync (bit1) nor link status (bit0). The state is 0x800.
* The Phy and the board are working, as I can use the MB-Design with lwip-example project.
Regarding the following answers concerning configuring the TI phy with SGMII on VCU118:
[1] How to bring up the SGMII PHY
[2] SGMII Ethernet of VCU118
[3] VCU118 SGMII Ethernet
Documentation:
[5] pg051-tri-mode-eth-mac
[6] pg138-axi-ethernet
I designed the IP core and wrote a startup FSM which configures the IP core through axi.
In order to make sure, the phy and the board are working I used the lwip-example project. The example-project works fine. I then studied the microblaze C code in order to make sure to have the correct configuration FSM states. The microblaze code goes through all the configurations I would expect from the documentation [5,6] and the above links [1-3]. Although I do the same configuration steps in my configuration FSM as in the microblaze code, I don't find the TEMAC status register (addr 0x30) go into "link up" state (i.e. bits 2-0 are expected to be 0x7 but they remain 0x0).
Am I doing the configuration steps also stated in [2] and in [1] in the correct order?
Can you please relate to what I am missing?
Here are my configuration steps:
I customized the IP core with the following settings:
Configuration-FSM:
I want to use this core without Microblaze. Therefore, I modified a initialization FSM from a previous Xilinx-Example-Project. This FSM goes through various stages to start the externel TI phy for use with 6-wire SGMII.
The code is the following:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
library work;
entity ethernet_config_axi_lite is
Generic(
  REJECT_BROADCAST_FRAME  : BOOLEAN := TRUE;
  REJECT_MULTICAST_FRAME  : BOOLEAN := FALSE;
  ACCEPT_BAD_FRAMES       : BOOLEAN := FALSE;
  PROMISCUOUS_MODE        : BOOLEAN := FALSE;
  MAC_UNICAST_ADD         : STD_LOGIC_VECTOR(47 downto 0) := x"010203040506"
port (
        s_axi_aclk         : in  STD_LOGIC;
        s_axi_resetn	   : in  STD_LOGIC;
	probe_axi_state    : out STD_LOGIC_VECTOR(7 downto 0);
	probe_axi_stack    : out STD_LOGIC_VECTOR(7 downto 0);
	probe_axi_rd_data  :out STD_LOGIC_VECTOR(31 downto 0);
	probe_int_stat     : out STD_LOGIC_VECTOR(7 downto 0);
	probe_phy_stat     : out STD_LOGIC_VECTOR(31 downto 0);
	probe_temac_stat   : out STD_LOGIC_VECTOR(31 downto 0);
        probe_phy_model    : out STD_LOGIC_VECTOR(15 downto 0);
        probe_sgmii_reg    : out STD_LOGIC_VECTOR(31 downto 0);
	s_axi_awaddr	   : out STD_LOGIC_VECTOR(17 downto 0);
	s_axi_awvalid	   : out STD_LOGIC;
	s_axi_awready	   : in STD_LOGIC;
	s_axi_wdata        : out STD_LOGIC_VECTOR(31 downto 0);
	s_axi_wvalid	   : out STD_LOGIC;
	s_axi_wready	   : in STD_LOGIC;
	s_axi_bresp        : in STD_LOGIC_VECTOR(1 downto 0);
	s_axi_bvalid	   : in STD_LOGIC;
	s_axi_bready	   : out STD_LOGIC;
	s_axi_araddr	   : out STD_LOGIC_VECTOR(17 downto 0);
	s_axi_arvalid	   : out STD_LOGIC;
	s_axi_arready	   : in STD_LOGIC;
	s_axi_rdata        : in STD_LOGIC_VECTOR(31 downto 0);
	s_axi_rresp        : in STD_LOGIC_VECTOR(1 downto 0);
	s_axi_rvalid	   : in STD_LOGIC;
	s_axi_rready	   : out STD_LOGIC
end ethernet_config_axi_lite;
architecture rtl of ethernet_config_axi_lite is
   -- main state machine
   -- Encoded main state machine states.
   type state_typ is         (INIT,                   -- 0
                              WAIT_FOR_RESET_RESP,    -- 1
                              MDIO_SETUP,             -- 2
                              CNFG_RAF,               -- 3
                              CNFG_TX,                -- 4
                              CNFG_RX,                -- 5
                              CNFG_FLOW,              -- 6
                              CNFG_FILTER,            -- 7
                              CNFG_MAC_LO_ADDR,       -- 8
                              CNFG_MAC_HI_ADDR,       -- 9
                              CNFG_GAP1,              -- 10
                              READ_PHY_MODEL,         -- 11
                              EN_SGMIICLK_WAIT_RDY,   -- 12
                              EN_SGMIICLK_1,          -- 13
                              EN_SGMIICLK_2,          -- 14
                              EN_SGMIICLK_3,          -- 15
                              EN_SGMIICLK_4,          -- 16
                              CNFG_GAP2,              -- 17
                              POLL_SGMII_CLK_UP,      -- 18
                              CHECK_SGMII_CLK_UP,     -- 19
                              WRITE_PHY_CTRL_REG,     -- 20
                              WRITE_PHY_CFGR2_REG,    -- 21
                              DIS_RGMII_1,            -- 22
                              DIS_RGMII_2,            -- 23
                              DIS_RGMII_3,            -- 24
                              DIS_RGMII_4,            -- 25
                              EN_SGMII,               -- 26
                              POLL_AUTONEG_CMPLT_1,   -- 27
                              CHECK_AUTONEG_CMPLT_1,  -- 28
                              WORK_AROUND_1,          -- 29
                              WORK_AROUND_2,          -- 30
                              WORK_AROUND_3,          -- 31
                              WORK_AROUND_4,          -- 32
                              CNFG_GAP3,              -- 33
                              MDIO_STATS_POLL_CHECK,  -- 34
                              START_AUTONEG_2,        -- 35
                              POLL_AUTONEG_CMPLT_2,   -- 36
                              CHECK_AUTONEG_CMPLT_2,  -- 37
                              POLL_LINK_UP,           -- 38
                              CHECK_LINK_UP,          -- 39
                              CNFG_SPEED_2,           -- 40
                              EN_INTERRUPTS,          -- 41
                              RD_STAT1,               -- 42
                              RD_STAT2,               -- 43
                              WAIT_FOR_DELAY,         -- 44
                              WAIT_FOR_MDIO_RDY,      -- 45
                              WAIT_FOR_MDIO_POLL1,    -- 46
                              VERIF_SGMIICLK_1,       -- 47
                              VERIF_SGMIICLK_2,       -- 48
                              VERIF_SGMIICLK_3,       -- 49
                              VERIF_SGMIICLK_4,       -- 50
                              VERIF_SGMIICLK_5,       -- 51
                              VERIF_SGMIICLK_6,       -- 52
                              WAIT_FOR_MDIO_RDY2,     -- 53
                              WAIT_FOR_MDIO_POLL2,    -- 54
                              CNFG_SPEED_1            -- 55
   -- MDIO State machine
   type mdio_state_typ is    (IDLE,
                              SET_DATA,
                              INIT,
                              POLL);
   -- AXI State Machine
   type axi_state_typ is     (IDLE_A,
                              READ,
                              WRITE,
                              DONE);
   -- Reset addr filter reg address
   constant RESET_ADDFILTER_ADD    : std_logic_vector(16 downto 0) := "00000" & x"000";
   -- Interrupt status reg address                  (0x00C)
   constant INT_STATUS_ADD         : std_logic_vector(16 downto 0) := "00000" & x"00C";
   -- Interrupt enable reg address
   constant INT_ENABLE_ADD         : std_logic_vector(16 downto 0) := "00000" & x"014";
   -- TEMAC status reg address
   constant TEMAC_STAT_ADD         : std_logic_vector(16 downto 0) := "00000" & x"030";
   -- Management configuration register address     (0x500)
   constant CONFIG_MANAGEMENT_ADD  : std_logic_vector(16 downto 0) := "00000" & X"500";
   -- Flow control configuration register address   (0x40C)
   constant FLOW_CTRL_ADD          : std_logic_vector(16 downto 0) := "00000" & X"40C";
   -- Receiver configuration register address       (0x404)
   constant RECEIVER_ADD           : std_logic_vector(16 downto 0) := "00000" & X"404";
   -- Transmitter configuration register address    (0x408)
   constant TRANSMITTER_ADD        : std_logic_vector(16 downto 0) := "00000" & X"408";
   -- Speed configuration register address    (0x410)
   constant SPEED_CONFIG_ADD       : std_logic_vector(16 downto 0) := "00000" & X"410";
   -- Unicast Word 0 configuration register address (0x700)
   constant CONFIG_UNI0_CTRL_ADD   : std_logic_vector(16 downto 0) := "00000" & X"700";
   -- Unicast Word 1 configuration register address (0x704)
   constant CONFIG_UNI1_CTRL_ADD   : std_logic_vector(16 downto 0) := "00000" & X"704";
   -- Address Filter configuration register address (0x708)
   constant FILTER_CTRL_ADD        : std_logic_vector(16 downto 0) := "00000" & X"708";
   -- Frame filter bytes (3 to 0)  register address (0x710)
   constant CONFIG_FRAME_FILTER_1     : std_logic_vector(16 downto 0) := "00000" & X"710";
   -- Frame filter bytes (7 to 4)  register address (0x714)
   constant CONFIG_FRAME_FILTER_2     : std_logic_vector(16 downto 0) := "00000" & X"714";
   -- Frame filter bytes (11 to 8) register address (0x718)
   constant CONFIG_FRAME_FILTER_3     : std_logic_vector(16 downto 0) := "00000" & X"718";
   -- Frame filter mask bytes (3 to 0) register address (0x750)
   constant CONFIG_FRAME_FILTER_MASK_1 : std_logic_vector(16 downto 0) := "00000" & X"750";
   -- Frame filter mask bytes (7 to 4) register address (0x754)
   constant CONFIG_FRAME_FILTER_MASK_2 : std_logic_vector(16 downto 0) := "00000" & X"754";
   -- Frame filter mask bytes (11 to 8) register address (0x758)
   constant CONFIG_FRAME_FILTER_MASK_3 : std_logic_vector(16 downto 0) := "00000" & X"758";
   -- MDIO registers
   constant MDIO_CONTROL           : std_logic_vector(16 downto 0) := "00000" & X"504";
   constant MDIO_TX_DATA           : std_logic_vector(16 downto 0) := "00000" & X"508";
   constant MDIO_RX_DATA           : std_logic_vector(16 downto 0) := "00000" & X"50C";
   constant MDIO_OP_RD             : std_logic_vector(1 downto 0)  := "10";
   constant MDIO_OP_WR             : std_logic_vector(1 downto 0)  := "01";
   -- PHY Registers
   -- phy address is actually a 6 bit field but other bits are reserved so simpler to specify as 8 bit
   signal phy_addr                 : std_logic_vector(7 downto 0) := X"03";
   constant PHY_CONTROL_REG        : std_logic_vector(7 downto 0)    := X"00";
   constant PHY_STATUS_REG         : std_logic_vector(7 downto 0)    := X"01";
   constant PHY_ID_REG             : std_logic_vector(7 downto 0)    := X"02"; -- should be read as 0x2000
   constant PHY_MODEL_REG          : std_logic_vector(7 downto 0)    := X"03"; -- should be read as 0xA231
   constant PHY_ADVERTISE_REG      : std_logic_vector(7 downto 0)    := X"04";
   constant PHY_ABILITY_1_REG      : std_logic_vector(7 downto 0)    := X"05";
   constant PHY_1000BASET_CONTROL_REG : std_logic_vector(7 downto 0) := X"09";
   -- for VCU118 workaround
   -- TI DP83867 PHY special registers
   constant TI_PHY_REGCR           : std_logic_vector(7 downto 0) := X"0D";
   constant TI_PHY_ADDDR           : std_logic_vector(7 downto 0) := X"0E";
   constant TI_PHY_PHYCTRL         : std_logic_vector(7 downto 0) := X"10";
   constant TI_PHY_CFGR2           : std_logic_vector(7 downto 0) := X"14";
   -- TI DP83867 PHY bit definitions
   constant TI_PHY_REGCR_DEVAD_EN  : std_logic_vector(31 downto 0) := X"0000001F";
   constant TI_PHY_REGCR_DATA      : std_logic_vector(31 downto 0) := X"0000401F";
   constant TI_PHY_SGMIITYPE       : std_logic_vector(31 downto 0) := X"000000D3"; -- ext reg address
   constant TI_PHY_SGMII_CLK_EN    : std_logic_vector(31 downto 0) := X"00004000";
   constant TI_PHY_CR_SGMII_EN     : std_logic_vector(31 downto 0) := X"00000800";
   constant TI_PHY_CFGR4           : std_logic_vector(31 downto 0) := X"00000031"; -- ext reg address
   constant DP83867_R32_RGMIICTL1  : std_logic_vector(31 downto 0) := X"00000032"; -- ext reg address
   -- Signal declarations
   signal s_rjct_bcf : std_logic; -- reject broadcast frame
   signal s_rjct_mcf : std_logic; -- reject multicast frame
   signal s_acpt_bf  : std_logic; -- accept bad frames
   signal axi_status               : std_logic_vector(4 downto 0);   -- used to keep track of axi transactions
   signal mdio_ready               : std_logic;                      -- captured to acknowledge the end of mdio transactions
   signal axi_rd_data              : std_logic_vector(31 downto 0);
   signal axi_wr_data              : std_logic_vector(31 downto 0);
   signal mdio_wr_data             : std_logic_vector(31 downto 0);
   signal axi_state                : state_typ;                      -- main state machine to configure example design
   signal axi_state_stack          : state_typ;                      -- return to this state after pushing state and jumping to intermediate
   signal axi_state_2nd_stack      : state_typ;                      -- return value of jumps into wait for mdio ready
   signal mdio_access_sm           : mdio_state_typ;                 -- mdio state machine to handle mdio register config
   signal axi_access_sm            : axi_state_typ;                  -- axi state machine - handles the 5 channels
   signal start_access             : std_logic;                      -- used to kick the axi acees state machine
   signal start_mdio               : std_logic;                      -- used to kick the mdio state machine
   signal drive_mdio               : std_logic;                      -- selects between mdio fields and direct sm control
   signal mdio_op                  : std_logic_vector(1 downto 0);
   signal mdio_reg_addr            : std_logic_vector(7 downto 0);
   signal temp_reg                 : std_logic_vector(31 downto 0);
   signal writenread               : std_logic;
   signal addr                     : std_logic_vector(16 downto 0);
   signal delay_counter            : unsigned(28 downto 0) := (others => '1');
   -- to avoid logic being stripped a serial input is included which enables an address/data and
   -- control to be setup for a user config access..
   signal serial_command_shift     : std_logic_vector(36 downto 0);
   signal load_data                : std_logic;
   signal capture_data             : std_logic;
   signal write_access             : std_logic;
   signal read_access              : std_logic;
   signal s_axi_reset              : std_logic;
   signal s_axi_awvalid_int        : std_logic;
   signal s_axi_wvalid_int         : std_logic;
   signal s_axi_bready_int         : std_logic;
   signal s_axi_arvalid_int        : std_logic;
   signal s_axi_rready_int         : std_logic;
   signal design_on_board         : std_logic_vector(3 downto 0) := X"0";
begin
   s_rjct_bcf  <= '1' when REJECT_BROADCAST_FRAME  else '0';
   s_rjct_mcf  <= '1' when REJECT_MULTICAST_FRAME  else '0';
   s_acpt_bf   <= '1' when ACCEPT_BAD_FRAMES       else '0';
   ---- debug
   probe_axi_state <= STD_LOGIC_VECTOR(TO_UNSIGNED(state_typ'POS(axi_state), probe_axi_state'LENGTH));
   probe_axi_stack <= STD_LOGIC_VECTOR(TO_UNSIGNED(state_typ'POS(axi_state_stack), probe_axi_state'LENGTH));
   probe_axi_rd_data <= axi_rd_data;
   s_axi_awvalid <= s_axi_awvalid_int;
   s_axi_wvalid  <= s_axi_wvalid_int;
   s_axi_bready  <= s_axi_bready_int;
   s_axi_arvalid <= s_axi_arvalid_int;
   s_axi_rready  <= s_axi_rready_int;
   s_axi_reset <= not s_axi_resetn;
   -- Management process. This process sets up the configuration by
   -- turning off flow control, then checks gathered statistics at the
   -- end of transmission
   gen_state : process (s_axi_aclk)
   begin
      if s_axi_aclk'event and s_axi_aclk = '1' then
         if s_axi_reset = '1' then
            delay_counter   <= (others => '1');
            axi_state       <= WAIT_FOR_DELAY;
            axi_state_stack <= INIT;
            start_access    <= '0';
            start_mdio      <= '0';
            drive_mdio      <= '0';
            mdio_op         <= (others => '0');
            mdio_reg_addr   <= (others => '0');
            writenread      <= '0';
            axi_wr_data     <= (others => '0');
            phy_addr        <= X"03";
         -- main state machine is kicking off multi cycle accesses in each state so has to
         -- stall while they take place
         elsif axi_access_sm = IDLE_A and mdio_access_sm = IDLE and start_access = '0' and start_mdio = '0' then
            case axi_state is
               when INIT =>
                  drive_mdio    <= '0';
                  start_mdio    <= '0';
                  start_access  <= '1';
                  writenread    <= '0';
                  addr          <= INT_STATUS_ADD;
                  axi_state     <= WAIT_FOR_RESET_RESP;
               when WAIT_FOR_RESET_RESP =>
                  if (axi_rd_data(8) = '1' and axi_rd_data(7) = '1') then
                      -- bit8: PhyRstCmplt: 0 - PHY not ready,   1 - PHY ready
                      -- bit7: MgtRdy:      0 - TEMAC not ready, 1 - TEMAC ready
                      axi_state    <= MDIO_SETUP;
                  else
                      axi_state    <= INIT;
                  end if;
               when MDIO_SETUP =>
                  writenread       <= '1';
                  addr             <= CONFIG_MANAGEMENT_ADD;
                  axi_wr_data      <= X"0000005F";
                  axi_state_stack  <= CNFG_RAF;
               when CNFG_RAF =>
                  drive_mdio       <= '0';
                  writenread       <= '1';
                  addr             <= RESET_ADDFILTER_ADD;
                  axi_wr_data      <= x"0000" & '0' & s_acpt_bf & "00" & x"00" & '0' & s_rjct_mcf & s_rjct_bcf & '0';
                  axi_state        <= CNFG_TX;
               when CNFG_TX =>
                  writenread       <= '1';
                  addr             <= TRANSMITTER_ADD;
                  axi_wr_data      <= x"10000000";
                  axi_state        <= CNFG_RX;
               when CNFG_RX =>
                  writenread       <= '1';
                  addr             <= RECEIVER_ADD;
                  axi_wr_data      <= x"1000FFFF";
                  axi_state        <= CNFG_FLOW;
               when CNFG_FLOW =>
                  writenread       <= '1';
                  addr             <= FLOW_CTRL_ADD;
                  axi_state        <= CNFG_FILTER;
               when CNFG_FILTER =>
                  writenread       <= '1';
                  addr             <= FILTER_CTRL_ADD;
                  axi_state        <= CNFG_MAC_LO_ADDR;
               when CNFG_MAC_LO_ADDR =>
                  writenread       <= '1';
                  addr             <= CONFIG_UNI0_CTRL_ADD;
                  axi_wr_data      <= MAC_UNICAST_ADD(23 downto 16) & MAC_UNICAST_ADD(31 downto 24) & MAC_UNICAST_ADD(39 downto 32) & MAC_UNICAST_ADD(47 downto 40);
                  axi_state        <= CNFG_MAC_HI_ADDR;
               when CNFG_MAC_HI_ADDR =>
                  writenread       <= '1';
                  addr             <= CONFIG_UNI1_CTRL_ADD;
                  axi_wr_data      <= x"0000" & MAC_UNICAST_ADD(7 downto 0) & MAC_UNICAST_ADD(15 downto 8);
                  axi_state_stack  <= CNFG_SPEED_1;
               when CNFG_SPEED_1 =>
                  writenread       <= '1';
                  addr             <= SPEED_CONFIG_ADD; -- 0x410
                  axi_wr_data      <= X"80000000";
                  axi_state_stack  <= CNFG_GAP1;
               --- TEMAC configured ---
               when CNFG_GAP1 =>
                  axi_state        <= WAIT_FOR_MDIO_RDY;
                  axi_state_stack  <= READ_PHY_MODEL;
               when READ_PHY_MODEL =>
                  drive_mdio       <= '1';
                  start_mdio       <= '1';
                  mdio_op          <= MDIO_OP_RD;
                  mdio_reg_addr    <= PHY_MODEL_REG; -- 0x3
                  axi_state        <= EN_SGMIICLK_WAIT_RDY;
               --- Enable SGMII clock ---
               when EN_SGMIICLK_WAIT_RDY =>
                  probe_phy_model  <= axi_rd_data(15 downto 0);
                  axi_state_stack  <= EN_SGMIICLK_1;
               when EN_SGMIICLK_1 =>
                  drive_mdio       <= '1';
                  start_mdio       <= '1';
                  mdio_op          <= MDIO_OP_WR;
                  mdio_reg_addr    <= TI_PHY_REGCR; -- 0xD
                  axi_wr_data      <= X"0000001F"; -- TI_PHY_REGCR_DEVAD_EN
                  axi_state_stack  <= EN_SGMIICLK_2;
               when EN_SGMIICLK_2 =>
                  drive_mdio       <= '1';
                  start_mdio       <= '1';
                  mdio_reg_addr    <= TI_PHY_ADDDR; -- 0xE
                  axi_wr_data      <= X"000000D3"; -- TI_PHY_SGMIITYPE
                  axi_state_stack  <= EN_SGMIICLK_3;
               when EN_SGMIICLK_3 =>
                  drive_mdio       <= '1';
                  start_mdio       <= '1';
                  mdio_reg_addr    <= TI_PHY_REGCR; --0xD
                  axi_wr_data      <= X"0000401F"; -- TI_PHY_REGCR_DATA
                  axi_state_stack  <= EN_SGMIICLK_4;
               when EN_SGMIICLK_4  =>
                  drive_mdio       <= '1';
                  start_mdio       <= '1';
                  axi_wr_data      <= X"00004000"; -- TI_PHY_SGMII_CLK_EN
                  axi_state_stack  <= VERIF_SGMIICLK_1;
                --- Verify register content
-- (not necessary, but I wanted to check the MDIO and Phy registers are working
-- as expected.) when VERIF_SGMIICLK_1 => axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= VERIF_SGMIICLK_2; when VERIF_SGMIICLK_2 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_REGCR; -- 0xD axi_wr_data <= X"0000001F"; -- TI_PHY_REGCR_DEVAD_EN axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= VERIF_SGMIICLK_3; when VERIF_SGMIICLK_3 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_ADDDR; -- 0xE axi_wr_data <= X"000000D3"; -- TI_PHY_SGMIITYPE axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= VERIF_SGMIICLK_4; when VERIF_SGMIICLK_4 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_REGCR; --0xD axi_wr_data <= X"0000401F"; -- TI_PHY_REGCR_DATA axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= VERIF_SGMIICLK_5; when VERIF_SGMIICLK_5 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_RD; mdio_reg_addr <= TI_PHY_ADDDR; -- 0xE axi_state <= VERIF_SGMIICLK_6; when VERIF_SGMIICLK_6 => probe_sgmii_reg <= axi_rd_data; -- this works (checked with ILA) axi_state <= CNFG_GAP2; --- SGMII clock enabled --- when CNFG_GAP2 => drive_mdio <= '0'; delay_counter <= (others => '1'); axi_state <= WAIT_FOR_DELAY; axi_state_stack <= POLL_SGMII_CLK_UP; when POLL_SGMII_CLK_UP => start_access <= '1'; writenread <= '0'; addr <= TEMAC_STAT_ADD; axi_state <= CHECK_SGMII_CLK_UP; when CHECK_SGMII_CLK_UP => probe_temac_stat <= axi_rd_data; --if (axi_rd_data(2 downto 0) /= "000" ) then
-- unfortunately this state never changes. However, it changes in MB example.
if True then axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= WRITE_PHY_CTRL_REG; else axi_state <= POLL_SGMII_CLK_UP; end if; -- SGMII clock is on when WRITE_PHY_CTRL_REG => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= PHY_CONTROL_REG; -- 0x0 axi_wr_data <= X"00001140"; -- axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= WRITE_PHY_CFGR2_REG; when WRITE_PHY_CFGR2_REG => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_CFGR2; -- 0x14 axi_wr_data <= X"000029C7"; -- axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= DIS_RGMII_1; --- PHY configured when DIS_RGMII_1 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_REGCR; -- 0xD axi_wr_data <= X"0000001F"; -- TI_PHY_REGCR_DEVAD_EN axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= DIS_RGMII_2; when DIS_RGMII_2 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_ADDDR; -- 0xE axi_wr_data <= X"00000032"; -- DP83867_R32_RGMIICTL1 axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= DIS_RGMII_3; when DIS_RGMII_3 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_REGCR; -- 0xD axi_wr_data <= X"0000401F"; -- TI_PHY_REGCR_DATA axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= DIS_RGMII_4; when DIS_RGMII_4 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_ADDDR; -- 0xE axi_wr_data <= X"00000000"; axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= EN_SGMII; --- RGMII disabled when EN_SGMII => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_PHYCTRL; -- 0x10 axi_wr_data <= X"00000800"; -- TI_PHY_CR_SGMII_EN axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= POLL_AUTONEG_CMPLT_1; -- SGMII enabled -> Wait for autonegotiation when POLL_AUTONEG_CMPLT_1 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_RD; mdio_reg_addr <= PHY_ABILITY_1_REG; -- 0x5 axi_state <= CHECK_AUTONEG_CMPLT_1; when CHECK_AUTONEG_CMPLT_1 => if (axi_rd_data(14) = '0') then axi_state <= POLL_AUTONEG_CMPLT_1; else axi_state <= WORK_AROUND_1; end if; --- Autonegotiation passed when WORK_AROUND_1 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_REGCR; -- 0xD axi_wr_data <= X"0000001F"; -- TI_PHY_REGCR_DEVAD_EN axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= WORK_AROUND_2; when WORK_AROUND_2 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_ADDDR; -- 0xE axi_wr_data <= X"00000031"; -- TI_PHY_CFGR4 axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= WORK_AROUND_3; when WORK_AROUND_3 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_REGCR; -- 0xD axi_wr_data <= X"0000401F"; -- TI_PHY_REGCR_DATA axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= WORK_AROUND_4; when WORK_AROUND_4 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= TI_PHY_ADDDR; -- 0xE axi_wr_data <= X"00001170"; axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= CNFG_GAP3; --- Work around completed --- Change PHY_ADDR when CNFG_GAP3 => -- Change PHY_ADDR
-- this is something I found in the MB code to be crucial
-- however, my problem is already in a previous state, that TEMAC state doesn't go to "link up" phy_addr <= X"01"; delay_counter <= (others => '1'); axi_state <= WAIT_FOR_DELAY; axi_state_stack <= START_AUTONEG_2; when START_AUTONEG_2 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_WR; mdio_reg_addr <= PHY_CONTROL_REG; axi_wr_data <= X"00001340"; axi_state <= WAIT_FOR_MDIO_RDY; axi_state_stack <= POLL_AUTONEG_CMPLT_2; when POLL_AUTONEG_CMPLT_2 => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_RD; mdio_reg_addr <= PHY_STATUS_REG; -- 0x1 axi_state <= CHECK_AUTONEG_CMPLT_2; when CHECK_AUTONEG_CMPLT_2 => if (axi_rd_data(5) = '0') then axi_state <= POLL_AUTONEG_CMPLT_2; else axi_state <= POLL_LINK_UP; end if; when POLL_LINK_UP => drive_mdio <= '1'; start_mdio <= '1'; mdio_op <= MDIO_OP_RD; mdio_reg_addr <= PHY_ABILITY_1_REG; -- 0x5 axi_state <= CHECK_LINK_UP; when CHECK_LINK_UP => if (axi_rd_data(14) = '0') then axi_state <= POLL_LINK_UP; else axi_state <= CNFG_SPEED_2; end if; --- Link is up --- Change PHY_ADDR when CNFG_SPEED_2 => phy_addr <= X"03"; drive_mdio <= '0'; start_access <= '1'; writenread <= '1'; addr <= SPEED_CONFIG_ADD; -- 0x410 axi_wr_data <= X"80000000"; delay_counter <= (others => '1'); axi_state <= WAIT_FOR_DELAY; axi_state_stack <= EN_INTERRUPTS; when EN_INTERRUPTS => start_access <= '1'; writenread <= '1'; addr <= INT_ENABLE_ADD; -- 0x14 axi_wr_data <= X"00000034"; -- TxCmplt & RxMemOvr & RxCpmlt axi_state <= RD_STAT1; -- Let's really hope our ethernet now comes up. when RD_STAT1 => probe_phy_stat <= axi_rd_data; drive_mdio <= '0'; start_access <= '1'; writenread <= '0'; addr <= TEMAC_STAT_ADD; axi_state <= RD_STAT2; when RD_STAT2 => probe_temac_stat <= axi_rd_data; drive_mdio <= '1'; start_mdio <= '1'; mdio_reg_addr <= PHY_STATUS_REG; mdio_op <= MDIO_OP_RD; axi_state <= RD_STAT1; when WAIT_FOR_DELAY => if (delay_counter /= 0) then delay_counter <= delay_counter - 1; else axi_state <= axi_state_stack; end if; when WAIT_FOR_MDIO_RDY => drive_mdio <= '0'; -- make sure mdio is disabled start_access <= '1'; writenread <= '0'; addr <= MDIO_RX_DATA; axi_state <= WAIT_FOR_MDIO_POLL1; when WAIT_FOR_MDIO_POLL1 => if axi_rd_data(16) = '1' then delay_counter <= to_unsigned(500, 29); axi_state <= WAIT_FOR_DELAY; axi_state_2nd_stack <= axi_state_stack; -- return value of 2nd jump axi_state_stack <= WAIT_FOR_MDIO_RDY2; else axi_state <= WAIT_FOR_MDIO_RDY; end if; when WAIT_FOR_MDIO_RDY2 => start_access <= '1'; writenread <= '0'; addr <= MDIO_CONTROL; axi_state <= WAIT_FOR_MDIO_POLL2; when WAIT_FOR_MDIO_POLL2 => if axi_rd_data(7) = '1' then drive_mdio <= '1'; -- reactivate mdio axi_state <= axi_state_2nd_stack; else axi_state <= WAIT_FOR_MDIO_RDY2; end if; when others => axi_state <= INIT; end case; else start_access <= '0'; start_mdio <= '0'; end if; end if; end process gen_state; -------------------------------------------------- -- MDIO setup - split from main state machine to make more manageable gen_mdio_state : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if s_axi_reset = '1' then mdio_access_sm <= IDLE; elsif axi_access_sm = IDLE_A or axi_access_sm = DONE then case mdio_access_sm is when IDLE => if start_mdio = '1' then if mdio_op = MDIO_OP_WR then mdio_access_sm <= SET_DATA; mdio_wr_data <= axi_wr_data; else mdio_access_sm <= INIT; mdio_wr_data <= PHY_ADDR & mdio_reg_addr & mdio_op & "001" & "00000000000"; end if; end if; when SET_DATA => mdio_access_sm <= INIT; mdio_wr_data <= PHY_ADDR & mdio_reg_addr & mdio_op & "001" & "00000000000"; when INIT => mdio_access_sm <= POLL; when POLL => if mdio_ready = '1' then mdio_access_sm <= IDLE; end if; end case; elsif mdio_access_sm = POLL and mdio_ready = '1' then mdio_access_sm <= IDLE; end if; end if; end process gen_mdio_state; --------------------------------------------------------------------------------------------- -- processes to generate the axi transactions - only simple reads and write can be generated gen_axi_state : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if s_axi_reset = '1' then axi_access_sm <= IDLE_A; else case axi_access_sm is when IDLE_A => if start_access = '1' or start_mdio = '1' or mdio_access_sm /= IDLE then if mdio_access_sm = POLL then axi_access_sm <= READ; elsif (start_access = '1' and writenread = '1') or (start_mdio = '1' or mdio_access_sm = SET_DATA or mdio_access_sm = INIT) then axi_access_sm <= WRITE; else axi_access_sm <= READ; end if; end if; when WRITE => -- wait in this state until axi_status signals the write is complete if axi_status(4 downto 2) = "111" then axi_access_sm <= DONE; end if; when READ => -- wait in this state until axi_status signals the read is complete if axi_status(1 downto 0) = "11" then axi_access_sm <= DONE; end if; when DONE => axi_access_sm <= IDLE_A; end case; end if; end if; end process gen_axi_state; -- need a process per axi interface (i.e 5) -- in each case the interface is driven accordingly and once acknowledged a sticky -- status bit is set and the process waits until the access_sm moves on -- READ ADDR read_addr_p : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if axi_access_sm = READ then if axi_status(0) = '0' then if drive_mdio = '1' then s_axi_araddr <= "000000" & MDIO_RX_DATA(11 downto 0); else s_axi_araddr <= "000000" & addr(11 downto 0); end if; s_axi_arvalid_int <= '1'; if s_axi_arready = '1' and s_axi_arvalid_int = '1' then axi_status(0) <= '1'; s_axi_araddr <= (others => '0'); s_axi_arvalid_int <= '0'; end if; end if; else axi_status(0) <= '0'; s_axi_araddr <= (others => '0'); s_axi_arvalid_int <= '0'; end if; end if; end process read_addr_p; -- READ DATA/RESP read_data_p : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if axi_access_sm = READ then if axi_status(1) = '0' then s_axi_rready_int <= '1'; if s_axi_rvalid = '1' and s_axi_rready_int = '1' then axi_status(1) <= '1'; s_axi_rready_int <= '0'; axi_rd_data <= s_axi_rdata; if drive_mdio = '1' and s_axi_rdata(16) = '1' then mdio_ready <= '1'; end if; end if; end if; else s_axi_rready_int <= '0'; axi_status(1) <= '0'; if axi_access_sm = IDLE_A and (start_access = '1' or start_mdio = '1') then mdio_ready <= '0'; axi_rd_data <= (others => '0'); end if; end if; end if; end process read_data_p; -- WRITE ADDR write_addr_p : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if axi_access_sm = WRITE then if axi_status(2) = '0' then if drive_mdio = '1' then if mdio_access_sm = SET_DATA then s_axi_awaddr <= "000000" & MDIO_TX_DATA(11 downto 0); else s_axi_awaddr <= "000000" & MDIO_CONTROL(11 downto 0); end if; else s_axi_awaddr <= "000000" & addr(11 downto 0); end if; s_axi_awvalid_int <= '1'; if s_axi_awready = '1' and s_axi_awvalid_int = '1' then axi_status(2) <= '1'; s_axi_awaddr <= (others => '0'); s_axi_awvalid_int <= '0'; end if; end if; else s_axi_awaddr <= (others => '0'); s_axi_awvalid_int <= '0'; axi_status(2) <= '0'; end if; end if; end process write_addr_p; -- WRITE DATA write_data_p : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if axi_access_sm = WRITE then if axi_status(3) = '0' then if drive_mdio = '1' then s_axi_wdata <= mdio_wr_data; else s_axi_wdata <= axi_wr_data; end if; s_axi_wvalid_int <= '1'; if s_axi_wready = '1' and s_axi_wvalid_int = '1' then axi_status(3) <= '1'; s_axi_wvalid_int <= '0'; end if; end if; else s_axi_wdata <= (others => '0'); s_axi_wvalid_int <= '0'; axi_status(3) <= '0'; end if; end if; end process write_data_p; -- WRITE RESP write_resp_p : process (s_axi_aclk) begin if s_axi_aclk'event and s_axi_aclk = '1' then if axi_access_sm = WRITE then if axi_status(4) = '0' then s_axi_bready_int <= '1'; if s_axi_bvalid = '1' and s_axi_bready_int = '1' then axi_status(4) <= '1'; s_axi_bready_int <= '0'; end if; end if; else s_axi_bready_int <= '0'; axi_status(4) <= '0'; end if; end if; end process write_resp_p; end rtl;
The temac state remains after all configuration states in status 0x800. I expect 0x807, from what I have seen in the behavior of the lwip-example.
ILA-output:
Output of the lwip-example code with register states before configurationa and after configuration. As can be seen, some time after Enable SGMII Clock has been issued, the TEMAC goes into status 0x807:
-----lwIP TCP echo server ------
TCP packets sent to port 6001 will be echoed back
Skip Reset first time.
Phy divisor set (reg 0x500).
Initial settings
old reg => new regs (before MAC addr set and Phy_setup())
0x000: 0x00000000 => 0x00000004
0x030: 0x00000800 => 0x00000800
0x404: 0x1000FFFF => 0x1000FFFF
0x408: 0x10000000 => 0x10000000
0x40C: 0x60000000 => 0x60000000
0x410: 0x80000000 => 0x80000000
0x500: 0x0000005D => 0x0000005D
0x700: 0xFFFFFFFF => 0xFFFFFFFF
0x704: 0x0000FFFF => 0x0000FFFF
0x708: 0x80000000 => 0x00000000
set MAC addr.
XAxiEthernet_SetMacAddress: setting mac address to: 01:02:03:04:05:06
0x700: 0xFFFFFFFF => 0x04030201
0x704: 0x0000FFFF => 0x00000605
phy registers (phy_addr=3):
0x0: 0x1140
0x1: 0x7949
0x4: 0x1E1
0x5: 0x0
0x9: 0x300
0xA: 0x0
0x10: 0x5848
0x11: 0x2
0x13: 0x40
0x14: 0x29C7
0x31: 0x10B0
0x32: 0xD3
0x37: 0x0
0x38: 0x0
0xD3: 0x0
0xDC: 0x3800
Enable SGMII Clock
short after sgmii clk en - 0x030: 0x800
long  after sgmii clk en - 0x030: 0x807
reg(0x0) = 0x1140
reg(0x14) = 0x29C7
Disable RGMII
Enable SGMII
reg(0x10)=0x800
Waiting for Link to be up
reg(0x5)_b14=1...
Auto negotiation completed for TI PHY on phy_addr=3
Work around complete.
0x000: 0x4
0x030: 0x807
0x404: 0x1000FFFF
0x408: 0x10000000
0x40C: 0x60000000
0x708: 0x0
redefine phy_addr from phy_addr=3to phy_addr=1
Start PHY autonegotiation, phy_addr: 1
control_reg (reg 0x0, phy_addr 1) write : 0x1340
phy status reg(0x1): 0x1C8
Waiting for PHY to  complete autonegotiation... completed (phy status reg (0x1): 0x1F8)
Waiting for Link to be up... completed (bit 15 set in reg 0x5: 0xD801)
0x0: 0x1140
0x1: 0x796D
0x4: 0x1E1
0x5: 0xCDE1
0x9: 0x300
0xA: 0x3C00
0x10: 0x800
0x11: 0xBC02
0x13: 0x1C42
0x14: 0x29C7
0x31: 0x1170
0x32: 0x0
0x37: 0x3
0x38: 0x1
0xD3: 0x4000
0xDC: 0x3800
auto-negotiated link speed: 1000
speed set 0x410: 0x80000000 => 0x80000000
Starting AxiEthernet Transmitter...
Starting AxiEthernet Receiver...
interrupt enable reg = 0x0 (before enabling)
interrupt enable reg = 0x18 (after enabling)
DHCP Timeout
Configuring default IP of 192.168.1.10
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
TCP echo server started @ port 7
I read the TEMAC status register (addr 0x30) directly after enabling the SGMII clock. Then I go into a long for-loop in order to wait a moment and read the register (addr 0x30) again. It is 0x807. This corresponds to the first states of my FSM. I do not understand, why the TEMAC in my design remains in status 0x800...
Do you think this is related to the IP customization?
What else should I check?
Thank you so much for your help in advance.
Best regards,
Cheebi
