VCU118 lwip echo
Hello
I am using Microblaze Example design on vivado to test the lwip echo server.
I am not able to run echo server on VCU188 microblaze example design.
i have read here that this is a know issue.
https://www.xilinx.com/support/answers/68277.html
so i also made the design ( shown below) on one of the latest versions  i.e. vivado 2018.3.  it also doesnt work on this version.
i read on the forum that i have to disable, autonegotiation, and fix to speed in lwip BSP settings. i also did it.
and i also didnt work (console output is shown below).
Could you please guide me how to make it work ?
Best Regards
Rizwan
block design
console output
-----lwIP TCP echo server ------
TCP packets sent to port 6001 will be echoed back
link speed: 100
Ethernet Link down
link speed: 100
Ethernet Link up
Ethernet Link down
link speed: 100
Ethernet Link up
Ethernet Link down
DHCP Timeout
Configuring default IP of 192.168.1.10
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
TCP echo server started @ port 7
link speed: 100
Ethernet Link up
Ethernet Link down
link speed: 100
Ethernet Link up
Ethernet Link down
link speed: 100
Ethernet Link up
Ethernet Link down
link speed: 100
Ethernet Link up
Ethernet Link down
link speed: 100
Ethernet Link up
Ethernet Link down
link speed: 100
