Participant sachinb_apt1
VCU118 with -3 speedgrade
The VCU118 userguide doesnt specify the speedgrade of the vu9p device onboard.
May i know if the board with -3 speedgrade available?
Scholar u4223374
Re: VCU118 with -3 speedgrade
He means that with appropriate rework gear, you could remove the -2L device and install a -3. Presumably you would also have to bump up the core voltage a bit, as I think the -2L runs at a lower voltage than the -3.
@sachinb_apt1
It does. Check Page 6-8 where the device is listed. It has a XCVU9P-L2FLGA2104 device (-2L speedgrade)
-3 speedgrade is not available though you can swap if you choose to.
- Giri
What do you mean by swap if i want to?
Are you saying i should ask for -3 device based VCU board during ordering ? Kindly elaborate.
@sachinb_apt1 Sorry if it wasn't clear. I meant you will need to order a -3 part and replace the one on VCU118 with it at your cost/risk. The board though comes only with -2L part.
- Giri
Scholar u4223374
If i understand correctly, the FPGA is not soldered to the PCB but something is holding it on, like some clips.
And we could remove the -2 part and replace with a -3.
Also, if there is risk involved in replacing such parts, Xilinx should give an option to buy board with any speedgrade.
Note: I have access to the board located at remote location,but i cant see it.
Guide avrumw
Guide
I am pretty sure this is not the case (I guess I can't be 100% certain, but...)
The FPGA is soldered to the board. To replace the FPGA would require the proper surface mount rework equipment - this is not something you can do with a soldering iron! There are companies that do surface mount rework (obviously for a fee).
Even with the best equipment, though, there is always a risk of failure of the rework, which can result in damage to both the board and the devices. This is not a minor undertaking...
Avrum
Alright Many thanks for the replies @avrumw @u4223374 and @gnarahar. Appreciate your help.
I dont think we will go ahead with re-work if theres risk involved in losing the board.
Scholar u4223374
@sachinb_apt1 These boards are all intended to be evaluation and development platforms, not final products. If the -2L isn't fast enough, just run the design a bit slower to check that it works, check that it meets timing for the -3 at full speed, and then design your final product around the -3.
As @avrumw has said, the chip is soldered down with over 2000 separate connections. It's definitely not a job for a beginner - but a person or company used to dealing with BGA chips should be able to reliably swap chips. Of course, at $45K each (for the -2L version; Digikey doesn't list the -3 yet) you'd want to be pretty sure of getting it right the first time.
