Verilog code using vivado
I have an original verilog code which utilized 1800 LUTs and 1400 Flipflops. Now I inserted some extra lines of code (state machine code) into the original verilod code. Expected result is more utilization of LUTs and FFs than the that of original values. But the problem is there is no increment in LUTs and FFs. They are same as original values. What might be the reason?
Without seeing the code and digging into it, the obvious answer was that much of your new logic was driven by constant values and so weeded out by the optimization pass.
Dan
Sir,
Two files have been attached. Obf1.txt is the original code. Obf2.txt is the file where extra code is inserted.
Extra code inserted:
reg c=1'b0;
reg[3:0] code_word;
reg[3:0] present_state, next_state;
parameter S0 = 4'b0000, S1 =4'b0001, S2 = 4'b0010, S3 = 4'b0011, S4 = 4'b0100 ,S5= 4'b0101, S6= 4'b0110, S7=4'b0111, S8=4'b1000, S9=4'b1001, S10=4'b1010, S11=4'b1011, S12=4'b1100, S13=4'b1101, S14=4'b1110, S15=4'b1111 ;
always @(posedge push or posedge RST_top)
begin
//if (dout !=1) begin
if (RST_top == 1)
present_state<= S0;
else
present_state<= next_state;
end
//end
always @(present_state or din or push)
begin
case(present_state)
S0: if(din == 1'b1) begin
next_state<= S13;
code_word<=4'b0011;
//dout<= 0;
end
else begin
next_state<= S10;
code_word<=4'b0110;
end
S10: if(din == 1'b1) begin
next_state<= S9;
code_word<=next_state | code_word;
//dout<= 0;
end
else begin
next_state<= S8;
code_word<=next_state & code_word;
end
S8: if(din == 1'b1) begin
next_state<= S12;
code_word<={next_state[3] , code_word[2:0]};
end
else begin
next_state<= S14;
code_word<= ~code_word;
end
S9: if(din == 1'b1) begin
 next_state<= S14;
 code_word<={next_state[3:1] , din};
 //dout<= 0;
 end
else begin
next_state<= S13;
end
S14: begin
 next_state<= S3;
 code_word<={din , code_word[3:1]};
 end
S13: begin
 next_state<= S12;
 code_word<= {code_word[1:0] , next_state[3:2]};
 end
S12: begin
 next_state<= S15;
 code_word<=  {code_word[3] , (~din) , code_word[1:0]};
 //dout<= 0;
 end
S15: begin
 next_state<= S3;
 code_word<=  {(~din) , code_word[2:0]};
 c<= 1'b1;
 end
S11: begin
 next_state<= S7;
 end
S3: if(din == 1'b1) begin
 next_state<= S5;
 //dout<= 0;
 end
else next_state<= S2;
S2: if(din == 1'b1) begin
 next_state<= next_state ^ code_word;
 //dout<= 0;
 end
S5: begin
 next_state<= S7;
 end
S7: begin
 next_state<= S6;
 end
S6: if(din == 1'b1) begin
  next_state<= S1;
  //dout<= 0;
  end
else next_state<= S5;
S1: begin
 next_state<= S2;
 end
S4: begin
  next_state<= S7;
  end
default next_state<= S0;
endcase
end
// C2: Outputs
always @(c)
begin
if(c) begin
dout<=1;
 //correct=S5;
end
 else begin
 //next_state<= S2;
 dout<= 0;
 end
 end
