jason_oberg
Video Starter Kit, LVDS Camera
I am trying to interface the LVDS Camera with the VIODC on the video starter kit.  I am basically trying to stream in data from the camera, store it in a frame buffer, and then display it on VGA.  The display portion of my design works fine.  I am having trouble getting the correct data from the camera.  I was wondering if anyone had detailed timing diagrams of the camera other than the ones that are including with the MT9V022 digital image sensor(the image sensor for the camera).  I need to know the relationship between the clock and the LVDS data signal.  I was also wondering if anyone has the correct register values for the MTV9022 digital image sensor that monochrome operation would work properly.  I have had a very difficult time finding the appropriate documentation for the camera and have tried to email Irvine Sensors (the manufacturer)
I have looked at the demo that is available but this was done using EDK and system generator.  I have done my design completely in Verilog.  I did find some initial register values for the camera in the Microblaze code but using these values did not seem to fix the problem.
Please help,
Jason
jason_oberg
Also, I used a Picoblaze processor for my I2C initialization.
martinthompson
The relationship between the LVDS clock and the LVDS data is a bit vague.  In the end, I changed my interface to sweep the pahse shift of a DCM through the databit to find a good sample point instead.
We'll have an IP core of this interface available soon...
Cheers,
Martin
Martin Thompson
martin.j.thompson@trw.com
http://www.conekt.co.uk/capabilities/electronic-hardware
atzkae
Hi Jason, i'm using Virtex-4 video starter kit and i need to extract the video image from the CMOS camera for image processing. Can you guide me? Desperately need your help. My email, atzkae@hotmail.com
Regard,
atzkae
sunny040
hi jason , I am also working od video starter kit virtex 4 ml402 platform. I need your help in getting the stored data coming from the camera so that i can use it for further processing.
shuklaankita
hello jason, can u please guide me with the code to take an image from camera and store it on the ml402 board fpga
xc4vsx35.....
Please help me out this is a module of my final year project...... I have to submit by march.....
my email id is shuklaankita132gmail.com
Waiting for ur reply.......
