JWJ
Virtex-4 ML401 Bill of Material (BOM)
Hello, I'm looking for a Bill of Material for the Virtex-4 ML401 evaluation board in conjunction to a Letter of Volatility.  The searches on this forum all point to the BOM.  TIA!
anatoli
Hello @JWJ ,
Looks like the older files got archived on the Xilinx website.
As such, i've sent you the ML401 BOM file via email.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
ddn
@JWJ ,
Please refer this AR#73458 regarding Letter of Volatility of Xilinx Evaluation boards.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
JWJ
Thanks for your response, but I'm looking for the Virtex-4 ML401 Bill of Material.  Appreciate it!
anatoli
Hello @JWJ ,
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
JWJ
Thanks Anatoli, that was exactly what I was looking for. Appreciate you digging and coming up with the BOM. You rock!
