05-14-2011 11:12 PM
I'm trying to test out a new ML605 (rev D) evaluation kit and the BIST demos that came with the compact flash card to verify board functionality. None of the demos have worked at all so far. I followed the instructions when first starting up the board - setting DIP switches, installing + configuring the USB-to-UART bridge/Tera Term - in the Getting Started guide UG533. I set my port to COM2, and TeraTerm can connect to it, but no output shows up. I have a VGA monitor connected to the board as well to test DVI/VGA output, but that's always blank.
I tried reloading the compact flash card with contents of cf_image from the design files (rdf0017_13.1_c.zip), but no luck. I also used Impact to "download.bit" from the ready_for_download folder. Impact programmed the FPGA successfully, but still the demos didn't work.
After that, I followed the ML605 BIST guide (xtp056_13.1_c.pdf). I used SDK to program the FPGA with the system.bit file, the system_bd.bmm file, and initialized "bootloader" as the ELF in BRAM. It loaded successfully but still nothing. I tried connecting with xmd:
XMD% connect mb mdm JTAG chain configuration -------------------------------------------------- Device ID Code IR Length Part Name 1 0a001093 8 System_ACE_CF 2 64250093 10 XC6VLX240T MicroBlaze Processor Configuration : ------------------------------------- Version............................8.10.a Optimization.......................Performance Interconnect.......................PLB_v46 MMU Type...........................No_MMU No of PC Breakpoints...............1 No of Read Addr/Data Watchpoints...0 No of Write Addr/Data Watchpoints..0 Instruction Cache Support..........on Instruction Cache Base Address.....0x50000000 Instruction Cache High Address.....0x5fffffff Data Cache Support.................on Data Cache Base Address............0x50000000 Data Cache High Address............0x5fffffff Exceptions Support................off FPU Support.......................off Hard Divider Support...............off Hard Multiplier Support............on - (Mul32) Barrel Shifter Support.............off MSR clr/set Instruction Support....on Compare Instruction Support........on Data Cache Write-back Support......off Fault Tolerance Support............off Stack Protection Support...........off ERROR: MicroBlaze is under RESET. Check if the Reset input to MicroBlaze and its Bus Interfaces are connected properly UNABLE to STOP MicroBlaze
The RESET error worries me. But when I try to connect a second time, I get:
XMD% connect mb mdm JTAG chain configuration -------------------------------------------------- Device ID Code IR Length Part Name 1 0a001093 8 System_ACE_CF 2 64250093 10 XC6VLX240T ERROR: Could not detect MDM peripheral on hardware. Please check: 1. If FPGA is configured correctly 2. MDM Core is instantiated in the design
The mdm shows up in the system.mhs file connected to the plb and microblaze debug buses. I'm not sure what the deal is with the RESET error, or why it doesn't show up the second time. I checked the system.ucf file, it has
Net sys_rst_pin PULLUP; Net sys_rst_pin LOC= H10 | IOSTANDARD=SSTL15; ## System level constraints Net sys_rst_pin TIG;
and the active high reset agrees with the ML605 Hardware User Guide (UG534, pp 49-50).
I'm using all 13.1 tools on Vista 64-bit machine. I'm assuming the TeraTerm is connected to UART properly because 1) the SiLab USB-UART bridge shows up in my device manager and 2) TeraTerm doesn't complain about connecting to the COM port. I'm also fairly sure the CF is loading properly (the SystemACE status LED blinks at startup and then stays solid green). It's a 2 GB card by Transcend with FAT format (came with kit). Also I have Production version Virtex 6 FPGA (Manufacturer's ID = Xilinx xc6vlx240t, Version : 6) so I'm using the right design files ("C" and not "CES").
Any help on this would be great, I'd really appreciate it. Just running the startup demos is eating up design time...
Thanks!
07-11-2011 07:58 PM
hi, sorry for the delay but this was eventually solved. there was a cold joint for one of the power module's inputs (supplying the 3.3 V). we realized this after trying to use the user switches to turn on the leds but they never did. we used a voltmeter and turned out the switches weren't getting the right voltage. HTH
05-15-2011 08:12 AM
05-15-2011 11:08 AM
It initially showed up as COM7, which is the port I configured TeraTerm to. But I manually changed it to COM2 later. TeraTerm didn't give me errors connecting to either.
05-15-2011 11:17 AM
05-15-2011 01:35 PM
Thanks for the suggestions, but still no luck. TeraTerm is still blank.
One thing I should note is my device manager didn't have Ports (COM & LPT) tree prior to installing SiLabs (its a laptop). I added it by "Adding Legacy Hardware" and selecting "Ports" and then "SiLabs CP210x USB to UART Bridge" as the device driver. I doubt this is the problem though, windows seems to "detect" the board fine (it refreshes the Ports tree in Device Manager when I connect/disconnect the board).
05-17-2011 02:14 PM
I didn't see anywhere in you messages that you pressed the System ACE reset switch after bringing up the TeraTerm window and configuring the com port. Pressing the reset (SW3) is what brings up the display of options in the TeraTerm window.
05-18-2011 11:19 AM
Sorry I didn't mention it, but I've tried this several times as well. Resetting the SystemACE doesn't cause any output to show up on the TeraTerm.
05-18-2011 05:28 PM
There is a small chance that something was damaged in shipment and since it is a new board you could return it for a replacement with a RMA.
But, my speculation is that it is something with your PC. Have you tried another system?
What happens when you type into TeraTerm?
05-18-2011 08:56 PM
Nothing shows up when we type in TeraTerm. We've tried this on two laptops, one running Vista and another running Windows 7. We've switched between several COM ports as well.
I've also tried building a simple system of my own and a program in SDK that prints to RS232 (I've ensured RS232_Uart_1 are stdin/out). Nothing showed up on TeraTerm when I did this. Nor could I connect to microblaze through xmd - the "Please check: 1. FPGA is configured correctly 2. MDM Core is instantiated in the design" error came up again.
I also tried the base reference design demo (ml605_brd) for ethernet/image filtering. When I connected the board to my Vista laptop, several LEDs beside the ethernet jack on the board lit up: the DUP and 1000 lights were solid, and the Rx light blinked green. But when I tried connecting to a network interface through the gui, the status was "Not connected to FPGA". Also when I ran this demo gpio LEDS #2-8 and the LED beside the Centre user switch (LED DS16) lit up on the board, which I found a bit odd for an ethernet demo...
06-16-2011 02:16 PM
Was this ever resolved? I have the exact same problem.
07-11-2011 07:58 PM
