Virtex VC707 - XPS License
I've bought a Virtex7 VC707 Evaluation Kit. Within this kit I expected to get a license (to this device) with full access to Vivado, ISE and SDK. This license was generated on Xilinx website with my Voucher number.
BUT, I cannot access XPS, it returns there's no valid license.
Whats going on ? I am missing something or what?
Re: Virtex VC707 - XPS License
Contact customer service via http://www.xilinx.com/askx/customer_service_form.htm
Thanks,Vijay
@antonioaugusto
could you post the error message you are getting at your end?
Please post your xinfo file to check the license.
you can generate xinfo by following below steps:-
To generate Xinfo report just go to Startà All Programs àXilinx Design toolsàISE Design Suite14.xà Accessories à Xinfo System Checker and after you run “Xinfo System Checker”, the Xinfo.txt report will be
generated and saved in your C (Home Drive):\Xilinx\14.x\ISE_DS\common folder, as a text file (.txt).
Hi, find attached the files.
The error on the printscreen is when XPS is called from Vivado.
@antonioaugusto
please check the following
http://www.xilinx.com/support/answers/52412.html
Xilinx Evaluation Kits are shipped with a node-locked license, device-locked to the device on the Evaluation Kit.
The "Full seat Vivado™ Design Suite: Design Edition - Device-locked to the Virtex-7 evaluation board XC7VX485T FPGA" license and  also covers the other packages of the XC7VX485T devices
It should work for XPS also.
Please check whether the following AR http://www.xilinx.com/support/answers/42067.htm gives any useful information
Check the table in the following table to know the features being supported with Vivado Design Edition license: http://www.xilinx.com/products/design-tools/vivado/index.htm
