kisun74
Vivado(2014.2) hangs in place_design
I'm using VC709 evaluation board, and Vidado 2014.2.
Vivado Hangs in place_design phase 4.2.
Log is as following.
Phase 4 Detail Placement
Phase 4.1 Commit Multi Column Macros Phase 4.1 Commit Multi Column Macros | Checksum: 198ba4a46
Time (s): cpu = 00:11:04 ; elapsed = 00:07:03 . Memory (MB): peak = 2652.477 ; gain = 212.039
Phase 4.2 Commit Most Macros & LUTRAMs
In our previous implementation, there is no problem. But,this time, Vivado hangs.......
What's the main cause of this hang?
kisun74
I resolve this hang problem by change place_design option from default to quick.
I'm not sure this is real good solution for it.
kisun74
vishalaggra
I am facing the same issue vivado 2014.2 hangs during place_design step 4.2.
If i restart vivado and start a fresh run, then it goes through fine. It problem shows up intermittently.
rholschbach
I also have been seeing  this hang using 2014.2.  I'm using window 7 64.  I check the task manager to see if the performance is close to idle then assume it must be hung.
xuecunhua2
I'm using windows 7 64-bit vivado2014.2. I already restart many times, same hang issue as described by author above: hang at place_design 4.2 phase. I'm trying to use "-quick" place option to see whether it solve the problem or not.
marcb
Is there an archived design available to look into this issue with. The File -> Archive Project option would provide a reproducible design to work with.
Marc
