gma-87
What Os for ZYNQ ?
hello,
i try to found a datasheet, so i can follow it, to install an Operation system on ZedBoard,
can i install :
ubuntu ( i found that ubuntu 13.10 , can support ARM processor  [ check this page http://releases.ubuntu.com/13.10/ ]  )
Mutekh ( http://www.mutekh.org/trac/mutekh ) , it support ARM processor ?
thank you
My blog : www.xilinx-video.blogspot.com
Tags (4)
htsvn
To run ubuntu on Zynq platform, refer to http://www.wiki.xilinx.com/Ubuntu+on+Zynq
--Hem
umamahe
The following AR http://www.xilinx.com/support/answers/52599.htm helps to find out answers for your query
gma-87
thank you for the response,
for the ubuntu  Os on ZYNQ, it's fine :)
but, i search for other Os, thant can be supported by ZYNQ, for example, the Mutekh ?
thanks
