What are the easy to use cmos sensors for ZYNQ?
Hello, guys.
Currently, I am doing a multi camera related project using ov7670.
For a better image quality, I am trying to change the image sensor. ov7670 is easy to use but it is way too old.
What are the popular and easy to use image sensors these days?
Re: What are the easy to use cmos sensors for ZYNQ?
This is a 8-bit parallel output sensor with i2c interface. Almost any image sensor fits into this category so just pick your sensor and make sure it has the same style output. If the output is wider, you can always ignore the lower bits.
Thanks for the information!
