What is the model# of the power supply included in the VC709 evaluation kit?
Hi all,
The power adapter has gone walkabout for our VC709 board. Does anyone have the kit, they can take a photo of the adapter label and post so I might source a replacement. Also the name of a trusted vendor would be helpful
Thanks!
Thom,
Have you seen our AR67507? Should have what you are looking for. Should be able to order one from Digilent if not other electronics component vendors/distributors.
T
