Visitor doohan93
Which fmc card is compatible with VCU118 for hdmi??
I'm going to buy ultrascale+(VCU118) board for hdmi verification.
I have a inrevium FMC card(TB-FMCH-HDMI4K) and i knew inrevium FMC card(TB-FMCH-HDMI4K) is not compatible with VCU118.
Plz let me know which fmc card is compatible with VCU1188 for hdmi??
Doohan93
Re: Which fmc card is compatible with VCU118 for hdmi??
FMC is just a spec that our cards follow. Below is a list of know tested/working combinations that we have done.
https://www.xilinx.com/products/boards-and-kits/fmc-cards.html
However this is not a fully conclusive list, there are many other FMCs that will work with these boards we just don't list everything. Best solution is to check with your FMC manufacture to find out if they have tested their card with one of our boards.
Hello @doohan93,
If we compare both VCU118 and inrevium FMC card(TB-FMCH-HDMI4K) both are working on VITA 57.1 standard.
which makes them compatible theoretically.
But for a final confirmation one to one pin compatibility should be checked using schematic of both and also as suggested contacting the vendor of the FMC card would be better option to confirm if this will be compatible with the Xilinx Evaluation card or not.
Hope this helps.
Thank you.
