Which is the u-boot configure file on ZYNQ Ultrascale+ MPSOC ZCU102 rev 1.1
I buy a ZYNQ ultrascale MPSOC ZCU102 Evaluation Kit development board. The footprint on the board is ZCU102 rev 1.1. Now I want to realize the project about running Linux on arm A53 and compile the u-boot file. But I found that there are three configure files in the fold of u-boot-xlnx-xilinx about ZCU102 (u-boot-xlnx-xilinx-v2018.1\configs).
xilinx_zynqmp_zcu102_rev1_0_defconfig
xilinx_zynqmp_zcu102_revA_defconfig
xilinx_zynqmp_zcu102_revB_defconfig
which one is suit for my Evaluation Kit development board? Is that right to use the xilinx_zynqmp_zcu102_rev1_0_defconfig?
You should use this one:
Hi @stephenm , I am using ZCU104 rev 1.0 board. What should be the u-boot configure file in my case? I am guessing 'xilinx_zynqmp_zcu104_revC_defconfig' from the config file, but I am not sure.
