Winbond SPIx4 Flash access on SP601.
Hi, all,
I am working with a Xilinx SP601 evaluation board, trying to access the Flash(Winbond SPIx4 W25Q64) via the Xps_SPI IP in MicroBlaze system.
Up to now I can read the device ID and seems the read data also works.
The problem is when I tried write data to the Flash, it dose not work at all.
Following is the op parameters in tx fifo in sequence:
Read ID: 0x90(instruction), 0x0, 0x0, 0x0(address 0), 0x0, 0x0(2 dummy data for read out ID).
Result: 0xEF, 0x16(looks ok).
Write Enable: 0x06(write enable).
then Write Data: 0x02(PP), 0x20, 0x0, 0x0(address 0x200000), 0x1,...(10 data to be written to the flash)
After the write operation done, I tried to read out data from the above address(tx data: 0x03(RD), 0x20, 0x0, 0x0(read address 0x200000), 0x0...(10 dummy data)).
The read out data show all zeros!
After the Write Enable Instruction sent, I checked out the status registers, both read zeros!
As I checked the write_protect pin is all the time '1'.
Could someone help me out?
The last question: the write enable(0x06) can not be combined with the PP(0x02) transfer(without cs low-high transition)?
thanks a lot!
