Observer cole.jepson
XADC Voltage Not Accurate
I've followed this awesome example given by mhkang64 at http://zynqhowto.blogspot.com/2014/03/zynq-how-tolab3.html
and it works, but it doesn't give the best accuracy. Every two or three samples gives a voltage reading that is about 0.3 volts lower than it should (sample rate of once per 5 seconds). I am using a DC voltage source fed into the XADC (so I know the voltage is stable). I was wondering if this is a common problem and if you could direct me to an easy fix for this or a good article about how to get better readings off a Zybo board XADC. Currently, I specified channel averaging of 16 in the Vivado xadc wizard block (what does this actually do?).
Scholar austin
Re: XADC Voltage Not Accurate
I suggest you check your voltage source,
The sample and hold on the XADC can see transients as fast as 1 ns.
Maybe put a bypass cap across the +/- inputs t6o filter out any noise?
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
Austin Lesea
Principal Engineer
Xilinx San Jose
I have a nice benchtop multimeter hooked up to the same input as the voltage source so I'm pretty sure the source is accurate but I'll try a small cap. Thanks for the tip.
Scholar u4223374
Multimeters tend to do a lot of smoothing of the input; they're very accurate when the signal is steady but they're not designed to catch transients (which will definitely cause odd data on the ADC). For that sort of thing you need an oscilloscope.
You could try using a battery as the source (eg. a single AA with a voltage divider to cut it down to under 1V). That should be extremely stable.
