marquesni
XAPP1026 "Lightweight IP" problem P2p and interrupt
I use the application XAPP1026 "Lightweight IP" as an example. I cut the soft part to having only one application which sends UDP packets. I will read an area of RAM and I sent in UDP.
I have two questions in relation to this application:
1) I want to know what is the bus P2P (point to point) connected between the DDR2 RAM Mac IP and Ethernet?
2) Is it possible to trigger the function of sending data via an interrupt generated by HARD.
Below you find the code that I use for sending UDP packets:
#include <stdio.h>
#include <string.h>
#include "lwip/err.h"
#include "lwip/udp.h"
#include "xparameters.h"
#include "xutil.h"
#include "xio.h"
#define BUFSIZE (1400)
static Xuint32 buf[BUFSIZE];
#define ddr_BASEADDR 0x51000000
static unsigned eth_port = 5001;
static eth_server_started = 0;
static struct udp_pcb *connected_pcb = NULL;
static struct pbuf *pbuf_to_be_sent = NULL;
int z=0;
int
transfer_eth_data() {
int copy = 1;
err_t err;
struct udp_pcb *pcb = connected_pcb;
static int id;
int *payload;
int i,j;
if (!connected_pcb) {
                xil_printf("!connected_pcb\n\r");
return -1;
memcpy(pbuf_to_be_sent->payload, ddr_BASEADDR, BUFSIZE);
pbuf_to_be_sent->len =BUFSIZE;
if (!pbuf_to_be_sent) {
return -1;
// always increment the id
payload = (int*)(pbuf_to_be_sent->payload);
*payload = id++;
err = udp_send(pcb, pbuf_to_be_sent);
if (err != ERR_OK) {
xil_printf("Error on udp_send: %d\n\r", err);
return -1;
#if ALLOC_PBUF_ON_TRANSFER
pbuf_free(pbuf_to_be_sent);
#endif
return 0;
void
print_eth_app_header()
     xil_printf("%20s %6d %s\n\r", "eth server",eth_port,"$ tftp -i 192.168.1.100 PUT <source-file>");
int
start_eth_application()
struct udp_pcb *pcb;
struct ip_addr ipaddr;
err_t err;
u16_t port;
int j,i;
Xuint8 dataIn;
// create a udp socket
pcb = udp_new();
if (!pcb) {
xil_printf("Error creating PCB. Out of Memory\n\r");
return -1;
/* bind local address */
if ((err = udp_bind(pcb, IP_ADDR_ANY, 0)) != ERR_OK) {
xil_printf("error on udp_bind: %x\n\r", err);
// connect to iperf server
IP4_ADDR(&ipaddr,   192, 168, 1 ,100); // iperf server address /
port = eth_port;                            // iperf default port
err = udp_connect(pcb, &ipaddr, port);
for (j = 0; j < BUFSIZE ; j++)
XIo_Out32(ddr_BASEADDR+j,    0x11112222);
xil_printf("chargement ram ok");
connected_pcb = pcb;
pbuf_to_be_sent = pbuf_alloc(PBUF_RAW, BUFSIZE, PBUF_POOL);//
return 0;
